The current Thunderbird icon isn't very visible on the desktop, but I can't change it.
I don't have the necessary permissions ?
BITTE helft einander! Mehr auf meinem Blog http://herrabisz.wordpress.com/ http://www.youtube.com/user/HerrAbisZ2 + 3
You could remove the shortcut from the desktop and create a new user one so you get permissions to change the icon.
Thanks, but the same icon keeps showing up.
And if I change it to a different icon and then change it back, will the original icon—the one that's hard to see—come back
Would you post a screenshot of the "hard to see" icon please?
Are you able to change to another arbitrary icon?
Bitte schön
Well, select the icon with left mouse click and press "Del" key. Log out and in. Are you able to remove this icon from the desktop?
Now it is delet
Now create new shortcut > right mouse click on the desktop > create new > link to app > application tab > command = thunderbird > first tab: select icon > click ok, done
It`s the same sh...
I take Icon "agent"
Had this issue a while back
