#1 2026-10-08 20:13
HerrAbisZ
Icon by Thunderbird cannot be changed in 32-bit Trinity
The current Thunderbird icon isn't very visible on the desktop, but I can't change it.
I don't have the necessary permissions ?
BITTE helft einander! Mehr auf meinem Blog http://herrabisz.wordpress.com/ http://www.youtube.com/user/HerrAbisZ2 + 3
#2 2026-10-08 22:01
Re: Icon by Thunderbird cannot be changed in 32-bit Trinity
You could remove the shortcut from the desktop and create a new user one so you get permissions to change the icon.
#3 2026-10-09 07:43
HerrAbisZ
Thanks, but the same icon keeps showing up.
And if I change it to a different icon and then change it back, will the original icon—the one that's hard to see—come back
#4 2026-10-09 10:29
Would you post a screenshot of the "hard to see" icon please?
Are you able to change to another arbitrary icon?
#5 2026-10-09 11:24
HerrAbisZ
Bitte schön
#6 2026-10-09 11:36
Well, select the icon with left mouse click and press "Del" key. Log out and in. Are you able to remove this icon from the desktop?
#7 2026-10-09 11:56
HerrAbisZ
Now it is delet
#8 2026-10-09 12:04
Now create new shortcut > right mouse click on the desktop > create new > link to app > application tab > command = thunderbird > first tab: select icon > click ok, done
#9 2026-10-09 12:43
HerrAbisZ
It`s the same sh...
I take Icon "agent"
#10 2026-10-10 06:55
Had this issue a while back
Please see https://www.q4os.org/forum/viewtopic.php?id=5946
