#1 2025-11-08 07:45
PotentialUser
Display problems after installation
I have Installed Q4OS on my desktop computer. During the booting, initially the log screen appears as usual, but later the display turns black. Any keyboard input does not work. When I press the shutdown button, the log screen appears again, and it is shutting down. Booting  the older kernel does not help. When I start the recovery mode, I can log in with my password, but I do not know, what to do next. We have a very big screen, so it is hard to see the tiny characters, if they are in the left upper corner.
#2 2025-11-08 07:51
Re: Display problems after installation
Did you ever use a secondary screen? If so connect it again and see what happens.
#3 2025-11-08 14:07
Welcome to the forum @PotentialUser smile
Please post a brief hardware specification.
#4 2025-11-08 15:08
PotentialUser
This is the area from Q4os live Hardware Info:
(live System works)
System: Plasma 6.3.6 Q4os 6.1.1 deb13u1 (Andromeda)
Kernel: 6.12.43+deb13u1-amd64
CPU: Intel(R) Core(TM) i7-4790 CPU @3,6 GHZ
Ram: 12GB total 2 TB
Grafik Nvida GK104 [GeForce GTX 750 OEM]
Mainboard: Medion H81H3-EM2
#5 2025-11-08 15:17
PotentialUser
@hciper:
My computer has two HDMI ports which usually show different screens.
But in this case they are both black.
#6 2025-11-08 16:56
Are you able to boot and install from the Debian live ? "debian-live-13.1.0-amd64-kde.iso" , download https://cdimage.debian.org/debian-cd/cu … so-hybrid/
#7 2025-11-08 17:57
PotentialUser
I already installed from the Q4OS live. Should I rather install from the Debian live?
#8 2025-11-08 20:09
Do we understand correctly that the Q4OS installation is unusable ? If so, the alternative is to install from Debian live. Please post the result back for us to get a feedback for possible fix.
#9 2025-11-08 23:27
PotentialUser
Is there a opportunity, that I first install Debian and then upgrade it to QSO4?
#10 2025-11-08 23:50
Yes, install Debian and follow instructions https://www.q4os.org/dqa017.html
#11 2025-11-09 11:10
PotentialUser
I will try to Install Quarkos Noble Plasma live instead. Because it is inside the Q4OS Imager and I had not problems with Ubuntu before.
#12 2025-11-09 12:21
Yes, it's the fine way too.
#13 2025-11-15 08:25
PotentialUser
I tried the Quarkos live but could not boot it. Then I successfully installed de Ian. Which is now the easiest way to switch to q4os?
#14 2025-11-15 09:13
PotentialUser
I started the steps of https://www.q4os.org/dqa017.html
Then the script said everything is installed and I should reboot.
When I reboot I am in the former Debian again.
#15 2025-11-15 10:38
Please run in terminal:
$ get-q4os-version
$ qrepolist
and post back the output.
#16 2025-11-16 09:16
PotentialUser
$ get-q4os-version
6.1.1-deb13u1
$ qrepolist
deb http://deb.debian.org/debian/ trixie main contrib non-free non-free-firmware
deb http://security.debian.org/debian-security/ trixie-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ trixie-updates main contrib non-free non-free-firmware
deb http://q4os.org/q4repo/ q4os-6-0-cn main
#17 2025-11-16 11:56
Well, so you have Q4OS Plasma installed, all seem good., please see https://www.q4os.org/forum/viewtopic.php?id=5770
#18 2025-11-16 16:28
PotentialUser
Shall I succeed with following?
$ sudo qrepoadd mx-tools
$ sudo apt update
$ sudo apt install q4os-mxtools-plasma
or
$ sudo apt install q4os-mxtools-trinity
#19 2025-11-16 17:12
No, this method has a bug what is going to be fixed. We recommend you to use the preferred method using the .qsi installer, see https://www.q4os.org/forum/viewtopic.php?id=3477
#20 2025-11-17 07:57
PotentialUser
The links to the website aren't very clear for me.
Should I download this one?
setup_q4os-mxtools-plasma_5.3-a1.qsi
#21 2025-11-17 11:18
Yes, use setup_q4os-mxtools-plasma_<version>.qsi for Plasma or setup_q4os-mxtools-trinity_<version>.qsi for Trinity desktop. Download from here https://sourceforge.net/projects/q4os/f … ntal_apps/
#22 2025-11-20 08:29
PotentialUser
As I started "setup_q4os-mxtools-trinity_5.3-a1.qsi there was the error "Simulation not succesfull, sorry, I cannot install now.
...Unable to satify two dependicies Reaced two comflicting deciosions:
1. q4os-mxtools-trinity:amd64_5.3-a1 is selected to install
2.q4os-mxtools-trinity:amd64_5.3-a1 hängt ab von q4os-desktop-trinity
but none of the choices is installable
#23 2025-11-20 08:35
PotentialUser
Installing mxtools-plasma instead.
#24 2025-11-20 09:49
PotentialUser wrote:
As I started "setup_q4os-mxtools-trinity_5.3-a1.qsi ...
As we know you are using Plasma https://www.q4os.org/forum/viewtopic.ph … 763#p32763, so why didn't you start with mx-tools for Plasma .qsi installer ?
#25 2025-11-20 17:47
PotentialUser
Error after installation of mx-tools. plasma:
Copying system packages.. Done
Update sw database...
Widersprüchliche Werte gesetzt für Option Trusted betreffend due Quelle...
E: Die Liste der Quellen konnte nicht gelesen werden.
Testing installation : Done
