#1 2025-01-05 10:45
abhishek10
usb flash drive not showing
when i connect Kingston128 GB flash drive it not showing. i use  kde partition manager  but not showing my flash drive. but when i use cmd "lsusb" show this. how to solved this please help
#2 2025-01-05 13:29
Re: usb flash drive not showing
Plug in the flash drive then run
sudo inxi -Fxxxmprz
and copy/paste the results back here please.
#3 2025-01-05 16:01
abhishek10
System:
  Kernel: 6.1.0-28-amd64 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
    Distro: Q4OS 5.7.1-n1 base: Debian GNU/Linux 12 (bookworm)
Machine:
  Type: Desktop Mobo: N/A model: N/A serial: N/A UEFI: American Megatrends
    v: 4.6.5 date: 12/01/2022
Memory:
  RAM: total: 7.65 GiB used: 2.14 GiB (27.9%)
  Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
    note: est.
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix/Hyundai part-no: HMT8G1600JAIN-S.K serial: <filter>
  Device-2: ChannelB-DIMM0 type: no module installed
CPU:
  Info: dual core model: Intel Core i3-3220 bits: 64 type: MT MCP smt: enabled
    arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 1601 high: 1607 min/max: 1600/3300 volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 1600 2: 1607 3: 1597 4: 1600 bogomips: 26339
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Graphics:
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915
    v: kernel arch: Gen-7 ports: active: HDMI-A-1 empty: DP-1,VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.7 compositor: kwin_x11 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung S22C31x serial: <filter>
    res: 1920x1080 hz: 60 dpi: 102 size: 476x267mm (18.74x10.51")
    diag: 546mm (21.5") modes: max: 1920x1080 min: 720x400
  API: OpenGL v: 4.2 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 2500 (IVB
    GT1) direct-render: Yes
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
    class-ID: 0403
  API: ALSA v: k6.1.0-28-amd64 status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active (root, process)
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
    pcie: speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8136
    class-ID: 0200
  IF: enp2s0 state: down mac: <filter>
  Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
    bus-ID: 2-1.2:3 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
  IF: wlx90de809f40fd state: up mac: <filter>
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
    driver: btusb v: 0.8 bus-ID: 1-1.3:5 chip-ID: 0a12:0001 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 1.2
    lmp-v: 2.0 sub-v: c5c hci-v: 2.0 rev: c5c
Drives:
  Local Storage: total: 119.24 GiB used: 28.97 GiB (24.3%)
  ID-1: /dev/sda vendor: Plextor model: PX-128S3C size: 119.24 GiB
    speed: 3.0 Gb/s type: SSD serial: <filter> rev: 1.02 scheme: GPT
Partition:
  ID-1: / size: 107.86 GiB used: 28.97 GiB (26.9%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 5.9 MiB (2.0%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 8.8 GiB used: 512 KiB (0.0%) priority: -2
    dev: /dev/sda3
Sensors:
  System Temperatures: cpu: 25.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Repos:
  Packages: pm: dpkg pkgs: 2458
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/10_q4os.list
    1: deb http://q4os.org/q4repo q4os-5-0-cn main
  Active apt repos in: /etc/apt/sources.list.d/20_debian.list
    1: deb http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
    2: deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware
    3: deb http://deb.debian.org/debian/ bookworm-updates main contrib non-free non-free-firmware
  No active apt repos in: /etc/apt/sources.list.d/30_debian_backports.list
Info:
  Processes: 187 Uptime: 6h 12m wakeups: 0 Init: systemd v: 252
  target: graphical (5) default: graphical Compilers: gcc: 12.2.0 alt: 12
  Shell: Sudo (sudo) v: 1.9.13p3 default: Bash v: 5.2.15 running-in: konsole
  inxi: 3.3.26
#4 2025-01-06 08:09
OK.
Do any other flash drives work?
If they do then it is most likely the way the Kingston is formatted.
Is it new or has it worked OK in the past.
Has it been used on a Windows machine?
#5 2025-01-11 22:47
dwightparker
I have a similar problem. Following thread for possible solution. My case is any external hard drive plugged in does not show up or mount but they show up when I run lsblk.
#6 2025-01-12 08:20
With Plasma DE, right-click on the small black triangle (arrow up) next to the clock and select the item "Configure..."
Then look at the setting for the Device Notifier and check it is not "Disabled" in the drop-down list.
#7 2025-01-12 08:24
As you will have seen it is important to provide information about your system.
Please plug in a drive and then run
sudo inxi -FxxxmprzJ
and paste back the results.
When you plug a drive in and it doesn't 'show' it's a good idea to navigate to the /media folder and see if there is anything showing in there.
#8 2025-01-13 15:29
dwightparker
I got my situation fixed. I reformatted the external drive using gparted. Also, this revived new life into an old Acer Netbook with an Intel Atom processor and 2 gig of RAM. Of course I am using the 32 bit version. Netbook shipped with Windows 7 and was slow as crap from the beginning. Other versions of Linux worked but none have been as fast or responsive at Q4OS.... it also helped to put in a 250GB SSD. Not my main computer but I just dislike letting equipment sit around in a closet useless.
#9 2025-01-13 20:56
Ouch, Intel Atom is a really poor performer and Q4OS is a great choice to help that cpu. Im the same way as I have both older and newer hardware up and running as I tend to hardware hop all the time. Glad you got it working.
