#1 2023-04-05 10:55
Q4OS imager, an easy way to create Q4OS Live bootable USB
Q4OS imager is a tool for creating Q4OS Live bootable USB. The application enables downloading Q4OS installation and live media images and creating bootable USB in an easy way.
Installation from repositories:
$ sudo apt install q4os-imager
Download testing version for Windows:
https://q4os.sourceforge.io/download/q4 … .7.4.1.zip
Q4OS imager is derived from Raspberry Pi imager application.
#2 2023-04-05 21:24
hdwolf
Re: Q4OS imager, an easy way to create Q4OS Live bootable USB
Very good tool. I've remarked it by testing the r4 version of Aquarius, installing the Desktop flavour. Selected the Gemini Plasma Live image with usb-stick and all goes fine. Screenshot shows german language and says "SD-Karte" (SD-card). But an usb-stick is also functional. Proposal, "SD-Karte/USB-Stick" and for the button "Medium wählen".
#3 2023-04-30 17:50
New testing version for Windows has been released, download https://q4os.sourceforge.io/download/q4 … .7.4.1.zip
#4 2024-07-29 22:13
We plan to sign Q4OS imager for Windows with a dedicated signature, so the application will not show security confirmation dialogues.
#5 2024-11-29 16:06
niftyprose
I tried Imager for the first time today, and got a stroppy note saying that it couldn't open /dev/sda.
I then went old-school and typed the classic command into the terminal:
sudo dd bs=4M if=/home/yrmomma/Downloads/q4os-5.7-x64.r1.iso of=/dev/sda status=progress oflag=sync
Worked first time. Readers can draw their own conclusions.
#6 2024-11-29 16:19
What system did you run the imager on ?
You may need to unmount the drive first.
You can do that easier way:
$ sudo cp bootable.iso /dev/sdx
see https://www.q4os.org/dqa011.html#install.1
Don't do that on a mounted drive.
#7 2024-12-25 08:30
cdoublejj
sudo apt install q4os-imager  -->  E: Unable to locate package q4os-imager
#8 2024-12-25 08:38
cdoublejj
* Thats on PopOs btw, not arch
