#1 2023-04-05 10:55
Q4OS imager, an easy way to create Q4OS Live bootable USB
Q4OS imager is a tool for creating Q4OS Live bootable USB. The application enables downloading Q4OS installation and live media images and creating bootable USB in an easy way.
Download for Windows:
https://github.com/q4os/q4os-imager/rel … 7.6-a1.zip
Installation from repositories:
$ sudo apt install q4os-imager
Source code https://github.com/q4os/q4os-imager
#2 2023-04-05 21:24
hdwolf
Re: Q4OS imager, an easy way to create Q4OS Live bootable USB
Very good tool. I've remarked it by testing the r4 version of Aquarius, installing the Desktop flavour. Selected the Gemini Plasma Live image with usb-stick and all goes fine. Screenshot shows german language and says "SD-Karte" (SD-card). But an usb-stick is also functional. Proposal, "SD-Karte/USB-Stick" and for the button "Medium wählen".
#3 2023-04-30 17:50
New testing version for Windows has been released
#4 2024-07-29 22:13
We plan to sign Q4OS imager for Windows with a dedicated signature, so the application will not show security confirmation dialogues.
#5 2024-11-29 16:06
niftyprose
I tried Imager for the first time today, and got a stroppy note saying that it couldn't open /dev/sda.
I then went old-school and typed the classic command into the terminal:
sudo dd bs=4M if=/home/yrmomma/Downloads/q4os-5.7-x64.r1.iso of=/dev/sda status=progress oflag=sync
Worked first time. Readers can draw their own conclusions.
#6 2024-11-29 16:19
What system did you run the imager on ?
You may need to unmount the drive first.
You can do that easier way:
$ sudo cp bootable.iso /dev/sdx
see https://www.q4os.org/dqa011.html#install.1
Don't do that on a mounted drive.
#7 2024-12-25 08:30
cdoublejj
sudo apt install q4os-imager  -->  E: Unable to locate package q4os-imager
#8 2024-12-25 08:38
cdoublejj
* Thats on PopOs btw, not arch
#9 2025-08-27 06:10
Taige
Using different methods such as ventoy or rufus, could it cause problems when installing Q4os?
#10 2025-08-27 19:37
I've used Rufus as well as other imagers to create a bootable drive and really haven't had any issues.
#11 2026-04-15 09:27
alfredo
It's worth mentioning that this tool is currently only x64, and would not run on a x86 (32-bit system).
Otherwise it works wonderfully on a 64-bit system. Thank you ?️
#12 2026-04-15 09:38
Imager should work for 32bit too, so if not, it's a bug. Would you specify your 32bit sytem, so we can investigate ?
#13 2026-04-15 10:26
alfredo
Sure...
Windows 10
Version 22H2 (Buid 19045.6456)
32-bit OS, x64 CPU
I know, I know.. I didn't set up this system like this. Don't ask me why the system is 32-bit. I just want to get rid of it.
#14 2026-04-15 10:28
alfredo
When I try running the imager, a message in a wide blue box with white text says:
This app can't run on your PC
To find a version for your PC, check with the software publisher.
<Close>
#15 2026-04-15 10:41
Thanks we will investigate.
#16 2026-04-15 14:34
alfredo
Kindly note that the installer did not create a program shortcut in the Start menu. I had to find it under a path like "C:\Program Files\Q4OS\imager.exe", and run it from there. (I'm not sure about the exe file name, I'm recalling it from my memory). There was also a "cli" exe, but I didn't try it.
#17 2026-04-15 14:59
Yes, that's a known glitch, however it appears only if you install the program as a substituted user. If you install as a user with administrator permissions, it will create the shortcut for that user in start menu properly. In anyway thanks for the report smile
#18 2026-07-17 16:28
Source code is public https://github.com/q4os/q4os-imager , everyone is welcome to create issues https://github.com/q4os/q4os-imager/issues
#19 2026-07-20 18:23
Great tool, especially because it allows for all-in-one access to every Q4OS installation media under Windows. cool
Here's an additional finding: I extracted the installer to a folder in my Windows desktop (with an app called Universal Extractor or UniExtract) and it still ran fine (didn't test the actual downloading, though).
May I suggest that you make this an option when running Q4OS Imager installer, so it could claim so-called Windows portability?
( Rufus has it, BTW; for further info, check https://www.portablefreeware.com/faq.php )
#20 2026-07-21 12:59
joschalbertino
Where can I download the newest version of Q4OS- Imager I can`t find it on github? In witch Folder must I seek in this Source (:github.com/q4os/q4os-imager), so I had downloaded  this one here (:q4os.sourceforge.io/download/q4 … -1.7.5.zip)
Can anybody help?
#21 2026-07-21 13:03
Welcome to the forum @joschalbertino smile
The official download for Windows you find link in the OP https://www.q4os.org/forum/viewtopic.ph … 439#p24439
#22 2026-07-22 12:20
We have just released new q4os-imager version 1.7.5-a1. It's immediately available for download or install from repositories.
#23 2026-10-11 16:02
We have just released new q4os-imager version 1.7.6-a1. It's immediately available for download or install from repositories.
