#26 2023-11-28 17:20
HerrAbisZ
Re: Q4OS 5.3 Aquarius no installation of programs from the software center
I have just tested the new version 5.4 - same problem
BITTE helft einander! Mehr auf meinem Blog http://herrabisz.wordpress.com/ http://www.youtube.com/user/HerrAbisZ2 + 3
#27 2023-12-03 13:49
HerrAbisZ
On My Sony Vaio VPCEJ1J1E there is no trouble
perhaps a Bug with the BIOS ?
#28 2024-01-03 09:25
NoMoreWindows
I came to Q4OS to revive a 15 year old Acer laptop and had this exact same problem.
I abandoned  my attempts due to this problem because I thought it was a hardware problem.
I liked Q4OS so much I used Q4OS to replace Windows on my other PC's, something I wanted to do for a long time.
On the other PC's all works as expected, exact same installation.
Due to this post I might revisit my attempts to get the Old Acer working.
#29 2024-01-03 21:35
NoMoreWindows
All versions show the same problem on my old Acer 2GB system.
Runs everywhere else without problem.
Tried virtual machine with 512MB RAM, went nicely to the swap file.
I will not pursue this further because I don't really need that PC to run, it was just for fun.
#30 2024-01-03 22:28
Yes, the minimal requirements are valid. We have successfully tested it as virtual machines in Virtualbox. We are now preparing a fix for Q4OS installer and desktop profiler, so you can try it as soon as it's released.
#31 2024-01-03 22:43
NoMoreWindows
OK I investigated a bit further and wanted to delete my previous message which apparently is not possible, so I've overwritten it with my further findings. I'll be trying the fix!
#32 2024-01-03 22:50
The fix should be available from the regular Q4OS repositories in a few days.
#33 2024-01-04 16:41
HerrAbisZ
Will this also be fixed via an update or do I have to reinstall?
#34 2024-01-04 16:47
@HerrAbisZ
You will only need to update.
#35 2024-01-04 17:07
HerrAbisZ
Thanks for all!
#36 2024-01-12 12:03
We have fixed some issues for q4os-setup and desktop-profiler utility, you can check it now. You only need to update from repositories and reboot. A feedback would be appreciated.
#37 2024-01-12 16:25
HerrAbisZ
Sorry, same trouble
#38 2024-01-12 17:58
Did you try the fixed tools ?
#39 2024-01-12 20:10
NoMoreWindows
Sorry I can not confirm whether it is fixed or not.
The old PC kept on crashing with the Trinity 32 version.
I then tried the Trinity 64 live version. That worked (without the fix).
After I installed that version from the live system to the HDD, the PC wouldn't boot from the HDD anymore.
I wanted Q4OS on that PC just for fun, I'm not willing to spend more time keeping it alive.
On all my other PC's (2 desktops, 1 laptop, many virtual machines) I didn't have the problem, so I cannot confirm something improved there.
