#1 2017-11-02 16:42
TestUser
No desktop - Live CD
I downloaded this Q4OS Scorpion - 64bit / x64 ... 582 MBytes
When I booted the CD I only got the command line interface, no desktop.  Any suggestions as to what happened?
Thanks!
#2 2017-11-02 18:27
Re: No desktop - Live CD
The live CD should boot into the graphical user interface. Would you provide a short hardware specification please ? Also try to type 'X' + 'Enter' on the command line and post a screenshot or output, if possible.
#3 2017-11-02 22:25
Ive got older laptops that when I try to run/install Scorpion they get stuck at the command line and do nothing.  I switched to Orion  and had no issues.
#4 2017-11-03 09:53
Also could you let us know what hardware you are running it on, some users can offer better advice on different hardware.
#5 2017-11-03 19:50
If its older hardware 32bit might be worth a try.
#6 2017-11-04 08:21
So, having easy access to the Orion LiveCD might prove useful after all???  smile
#7 2017-11-04 19:09
Yes it can be helpful to have the live cd but at some point all distros move to simplify older offerings.
