I want to install Q4OS over an existing TDE 14.4 install and not have my existing home (and hopefully root) directory erased. I do understand that the installer will (hopefully) overwrite the existing TDE configuration files.
This requires a custom install, which I accepted. I had previously mounted the existing "/home" and "/" directories that I wanted to use.
I got this error message:
ERROR: You must first manually mount your filesystem(s) at "/target" to do a custom install.
I assumed that /target referred to the home and root directories. Was I wrong? What should I do now?
I have done similar custom installs on quite a few Debian versions in the past, so I have experience with doing that as well as quite a bit of system administration experience on Trinity Desktop, Ubuntu, Debian and BSD.
hardcase
You only need to mount the target partition for installer to copy root filesystem to, so run in terminal:
$ sudo mount /dev/sdX /target
where 'sdX' is the partition to make Q4OS installation to.
If you have defined a separate home partition, it should be created and populated by installer as well.
