#1 2017-10-13 21:22
hardcase
Custom Install problem
I want to install Q4OS over an existing TDE 14.4 install and not have my existing home (and hopefully root) directory erased.  I do understand that the installer will (hopefully) overwrite the existing TDE configuration files.
This requires a custom install, which I accepted.  I had previously mounted the existing  "/home" and "/" directories that I wanted to use.
I got this error message:
ERROR: You must first manually mount your filesystem(s) at  "/target"  to do a custom install.
I assumed that /target referred to the home and root directories.  Was I wrong?  What should I do now?
I have done similar custom installs on quite a few Debian versions in the past, so I have experience with doing that as well as quite a bit of system administration experience on Trinity Desktop, Ubuntu, Debian and BSD.
hardcase
#2 2017-10-18 09:27
Re: Custom Install problem
You only need to mount the target partition for installer to copy root filesystem to, so run in terminal:
$ sudo mount /dev/sdX /target
where 'sdX' is the partition to make Q4OS installation to.
If you have defined a separate home partition, it should be created and populated by installer as well.
