Hi forum,
I use Q4OS 1.8.8, Orion on older Dell Optiplex GX240's and it is working great but I saw news release today and was thinking of updating to new Q4OS 2.4, Scorpion. My quick question is, do I have to reinstall the new LTS Q4OS 2.4, Scorpion or is there a way to upgrade from Q4OS 1.8.8, Orion.
Also is my current 1.8.8 Orion an LTS? Sorry I did research that one, but I think looking down through the release notes, that it isn't?
I'm kind of guessing that I have to do a reinstall but hell I'll ask the experts.
Regards
ru5ty_buck3t
We would recommend you to keep using Orion, if it works well for you. Orion is a LTS as well, and will be supported until May 2020.
If you want, for some reason, upgrade to Scorpion, we strongly recommend you to perform a fresh installation, as there is no clean way to upgrade from Orion to Scorpion.
Thanks for that! I was also wondering about an upgrade path.
And thanks for all your hard work! Q4OS is a truly brilliant system!
@q4osteam Thanks for that information. I will hold off on updating on Scorpion for time being on the working Dell Optiplex GX240's and try the new release on a spare one. Keep up the great work ![]()
I just wanted to add that users can easily check if their system is compatible with Scorpion by using the live-cd version of Q4OS, I use it almost exclusively as I prefer to know in advance if everything will work OOTB.
Ive done quite a few installs so far and had no issues but systems like the gx240 will have issues .
Agre with Dai as Ive been using the livecd for testing and the installation cd for the installs.
Scorpion works great on my system which is an 11 year old Asus AMD Athlon 6000+. And those annoying TDE bugs appear to be fixed.
Many 10-12 year old systems will do fine with Scorpion but bios issues/ hardware configurations vary a lot and in some cases its been a no go in my recent installs.
Havent spotted any bugs so far and no reports from other users.
