#1 2017-09-10 20:22
Error, when I try to delete an action
Good day! Or evening, whatever...
When I try to Delete an action
I got an error...
#2 2017-09-11 12:17
Re: Error, when I try to delete an action
By which command do you run this configuration dialog exactly ?
Please run in terminal:
$ kcmshell khotkeys
try to perform the delete action and report back terminal output.
#3 2017-09-11 15:06
Command not found...
#4 2017-09-11 17:41
Sorry for the mistake the right command should be:
$ tdecmshell khotkeys
#5 2017-09-12 12:26
Crashed, without saying almost nothing...
#6 2017-09-12 14:09
I just tested on my machine and deleted the "hello world" action from the "Examples" without issue, I also rebooted into Orion (I usually use Scorpion) and tested it there with the same results. I know this doesn't really help much but just thought I'd let the devs know in case it helps.
#7 2017-09-12 19:35
@Dai_trying
We are not able to reproduce too, thanks for the report.
@Rademes
As it's not easily reproducible, we guess it's a TDE related glitch depending on a specific khotkeys configuration. You could edit the '$HOME/.trinity/share/config/khotkeysrc' config file and remove manually all references to this particular action.
