#1 2017-06-29 12:03
cidess16
Multiple monitor
Hello everyone. I'm new to linux. I recently installed Q4os on a laptop (Dell D610). My problem is that when I plug a screen into the VGA port, the PC does not detect it. If anyone can help me on this. Thanking you in advance.
PS: I do not speak English so I use translate to communicate.
#2 2017-06-29 15:00
Re: Multiple monitor
Programs>Accessories>System>TDERandRTray - Screen Resize and Rotate
This will put a screen icon in system tray next to clock
Click Icon in system tray
Select VGA:0
#3 2017-06-29 22:50
If youre using Orion you should be fine(bins advice) but Ive had some issues with some older Dell laptops with Scorpion and multiple monitor use.
#4 2017-06-30 05:02
cidess16
Hello, sorry for the late reply. Thank you, it works. And thank you to the developer of Q4os.
wink
#5 2017-06-30 22:27
Glad you got it working!
