Hello everyone. I'm new to linux. I recently installed Q4os on a laptop (Dell D610). My problem is that when I plug a screen into the VGA port, the PC does not detect it. If anyone can help me on this. Thanking you in advance.
PS: I do not speak English so I use translate to communicate.
Programs>Accessories>System>TDERandRTray - Screen Resize and Rotate
This will put a screen icon in system tray next to clock
Click Icon in system tray
Select VGA:0
If youre using Orion you should be fine(bins advice) but Ive had some issues with some older Dell laptops with Scorpion and multiple monitor use.
Hello, sorry for the late reply. Thank you, it works. And thank you to the developer of Q4os.![]()
Glad you got it working!
