#1 2017-05-07 20:12
Scorpion users
Hows your experience been with the latest version as Im going to be installing it after i do my laptops with 1.8.4. Not expecting major problems, just if there is anything youve experienced to be aware of, thanks CC
#2 2017-05-07 20:17
Re: Scorpion users
I've been running mainly Scorpion for months now with no major issues, I had a couple of UEFI issues initially but they have been sorted out now.
#3 2017-05-07 20:19
Re: Scorpion users
Good, thanks, so Ill go ahead and install it.  Im running only one UEFI system so shouldnt be any issues.  I use to run it but its been awhile.
#4 2017-05-08 06:31
aldrik
Re: Scorpion users
Hello, i'm running Scorpions too
Great system !
All run ok
- I don't like Firefox ESR version
- I can't have Nextcloud client (works ok in Q4os stable) : https://www.jurisic.org/index.php?post/ … e-in-3-min
Is it the same version of trinity between scorpion and orion ?
Have a good day
aldrik
#5 2017-05-08 09:08
Re: Scorpion users
Have you tried bulding the nextcloud client as described in this doc page I haven't tried it myself and there could possibly be a problem with dependencies but could be worth a shot.
I think the trinity version in Orion was updated a while back although I'm not sure it is the same version as Scorpion, logic would say that the stable version might be older than the testing one but I will have to wait for confirmation from the devs on that.
Firefox can be downloaded and run from it's own folder with no installation so you can use the latest version (53.0.2 (64-bit) on my system) if you want to keep it up to date, but you might have to install pulseaudio to get sound from it.
#6 2017-05-08 09:16
Re: Scorpion users
No, Scorpion is based on TDE 14.0.5 development version, while Orion uses TDE 14.0.4 stable.
#7 2017-05-08 15:08
aldrik
Re: Scorpion users
Hello and thank you for your help ; I don't test that because it's nextcloud and not owncloud. And i don't kown if they are equal.
I'll wait the debian 9.
Ownclient-client is in synaptic and work for the moment
Debian is using esr version but q4os ?
#8 2017-05-08 15:09
aldrik
Re: Scorpion users
Ok thank you team
It's very stable using all days but i'm not a power user
Have a good day
#9 2017-05-08 15:57
aldrik
Re: Scorpion users
With Scorpion, i don't have any sound
With pulseaudio, all is working ok
#10 2017-05-08 17:58
Re: Scorpion users
aldrik wrote:
Sorry I didn't check apt first and followed a link from the page you posted and didnt realise the different name until you said roll
Q4OS uses esr version too, I had an issue with thunderbird and installed that from mozilla site and while I was there decided to try the latest Firefox too.
#11 2017-05-08 18:47
aldrik
Re: Scorpion users
Dai_trying wrote:
Not a matter, I use Owncloud-client and I'll wait for a Nextcloud-client on stable version of Scorpion
Thunderbird is ok for me (45.8.0)
I don't know if esr version has all the avantages of normal version.
In my office we have esr version (but windows too) and I don't like it...
#12 2017-05-08 19:13
Re: Scorpion users
I had a problem connecting to gmail (a known mozilla bug) but it is fixed in 52.1 so needed the latest version.
I don't really see a huge difference, I imagine it's more behind the scenes changes.
#13 2017-05-08 22:40
Re: Scorpion users
Im not wild about the ESR version of Firefox either. ESR offers stability but none of the added features you get with the conventional Firefox version.
#14 2017-05-08 22:54
Re: Scorpion users
Just installed Scorpion and was pleasantly surprised.  Very stable, no issues but will be taking it to task to see if anything crops up. Im using older hardware from 2012 so its difficult to gauge versus Orion.
Ill put it thru its paces and see what happens.
#15 2017-05-09 22:19
Re: Scorpion users
How many of you are running Scorpion exclusively, just curious.
#16 2017-05-10 08:19
aldrik
Re: Scorpion users
I run it, and i'm just happy with it !!!!
#17 2017-05-10 10:42
Re: Scorpion users
I've been running it on my new laptop for hardware compatibility, but still run Orion on my other systems. I think Scorpion is very stable and have only had minor issues which have been easily resolved.
#18 2017-05-10 22:05
Re: Scorpion users
Im not at the point where Im going to rely on Scorpion but so far its very stable'
#19 2017-05-13 22:09
Re: Scorpion users
Been testing Scorpion, very stable OS for a test version.  Its better than the last time I had tried it and it bodes well for it becoming the future official Q4OS release.
