#1 2017-03-29 12:33
johnrpm
tap to click
How can I turn off tap to click, I found a command line argument but is not persistant after re-boot, can someone point me to a config file please.
#2 2017-03-29 13:42
Re: tap to click
Global config file:
'/etc/X11/xorg.conf.d/50-synaptics.conf'
If you want to set it per user basis, please first read http://www.q4os.org/dqa007.html#tchpad . You will need to run the command on session start, please see http://www.q4os.org/dqa011.html#desktop.6
#3 2017-03-29 14:03
Re: tap to click
And if anyone uses Scorpion you can edit the file /etc/X11/xorg.conf.d/60-libinput.conf and change the line
Option "Tapping" "true"
to read
Option "Tapping" "false"
and remember this is a global setting (affecting all users). smile
#4 2017-03-29 16:43
johnrpm
Re: tap to click
Thanks for the quick replies, I must say that q4os is very nice, I have been using lubuntu on a very old flybook, which after the latest updates ran very hot, system load was high on tickover, I tried the live version of q4os and it ran a lot cooler so did a full install, even replacing my beloved puppy, I have now done a full install on an old tosh portege, runs like a dream, so I donated because I am so pleased with q4os, I may even replace mint on the thinkpad.
Thanks again.
