#1 2016-11-07 20:54
Konqueror right click menu
Can I add a custom menu entry on right click in konqueror?
I want to be able to select files and directories and add them to a compressed backup file, or create a new backup file to use simply by right click and select "compress with ark" or something like that.
#2 2016-11-07 21:05
Re: Konqueror right click menu
Found it, I had to install tdeaddons-trinity roll
#3 2016-11-08 08:51
You could create custom konqueror service menu too. Please find example service menu file in the attachment, and copy it into the '$HOME/.trinity/share/apps/konqueror/servicemenus/' folder.
It will create 'krusader' context menu entry of the 'My Computer' desktop icon, just right click on the 'My Computer' desktop icon.
#4 2016-11-08 09:27
Thanks guys, that's a great little tip. smile
#5 2016-11-09 09:15
In addition, you can define different menu actions for different file types, see 'X-TDE-ServiceTypes' entry.
#6 2016-11-09 09:18
Thanks, I've been looking through the default entries in /opt/trinity/share/apps/konqueror/servicemenus/ for examples too. smile
#7 2017-03-10 17:38
rafaelramos
I also had this same question now...
Helped me a lot.
#8 2017-03-12 08:11
Neat!!!
#9 2017-03-14 20:50
rafaelramos
@Dai_trying, did you create the custom command for Ark by right clicking?
If so, can you post here please?
Grateful!
#10 2017-03-14 21:11
I installed tdeaddons-trinity package which added a lot of other packages but it was the simplest solution, just remember to log-out and back in to implement the addons. If you are having trouble creating it and don't want to install the addons I will look into it for you, let me know. smile
#11 2017-03-14 22:04
rafaelramos
Yes, I wanted to create the command natively, without the need to install the addons...
#12 2017-03-14 23:22
I just had a little look into this and although I can make it work sometimes I cannot figure out (at the moment) how to get it working properly.
I also looked at the packages and have found the package konq-plugins-trinity which has the required plugins and will only download a few dependencies (some of which might be required to get it working properly anyway) which could be a better choice.
Natively I cannot get what I would call a working solution and as this is available without the large download of the full trinity addons package I would say konq-plugins-trinity would be the recommended solution to this.
HTH
Dai
#13 2017-03-17 23:10
rafaelramos
Humm, interesting...
I'll follow your suggestion and take a slow look at these two packages that you've indicated (tdeaddons-trinity and konq-plugins-trinity).
Greetings!
