#1 2017-01-27 13:14
gurdonark
Possible update issue
Although  I read that new things are happening in Q4OS, my system has been returning the "your system is up to date" for several weeks, a bit longer than usual.  I tried the package updater and synaptic and got that result. From the command line, I ran
sudo apt-get update
and got the result:
Ign http://dl.google.com stable InRelease
Get:1 http://dl.google.com stable Release.gpg [916 B]
Get:2 http://security.debian.org jessie/updates InRelease [63.1 kB]
Get:3 http://dl.google.com stable Release [1,189 B]
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
When I run ~$ cat /etc/*_version , I get:
8.6
1.8.1-n1
I usually consider it a bit of a relief when my system says it is up to date, but I ask because your recent post on the site suggests that Orion updated to another version. I know once several weeks ago I had an issue in which the system said there were updates but then would not effectively load them. Though I thought this sorted out, as it often does on Q4OS, but now I wonder if an issue arose.
Is there some other step I should take, or is it just that I am up-to-date?
#2 2017-01-27 16:26
Re: Possible update issue
Sounds like you actually have somehow had apt-transport-https uninstalled.  Your updates aren't syncing the "main" debian repos nor the q4os repos (which are set as https by default).
I would try
apt-get install apt-transport-https
, although I have a feeling that'll fail.
In order to get it reinstalled, you may want to edit your sources.list and whatever your "main" debian repos are change it from https to http, do an apt-get update, THEN do the apt-get install apt-transport-https.  After it's installed, change back the repos to https in sources.list, apt-get update again, and this should then allow for all repos to syncronize properly again, and you'll get your updates.
#3 2017-01-27 21:39
I just ran sudo apt-get update on my system and it returned
Ign http://ftp.debian.org jessie InRelease
Get:1 http://ftp.debian.org jessie-updates InRelease [145 kB]
Hit http://q4os.org q4os-1-0-cn InRelease
Hit http://q4os.org jessie InRelease
Get:3 http://ftp.debian.org jessie-backports InRelease [166 kB]
Hit http://q4os.org q4os-1-0-cn/main amd64 Packages
Hit http://q4os.org q4os-1-0-cn/main i386 Packages
Hit http://ftp.debian.org jessie Release.gpg
Get:4 http://ftp.debian.org jessie-updates/main amd64 Packages/DiffIndex [6,916 B]
Get:5 http://ftp.debian.org jessie-updates/contrib amd64 Packages [32 B]
Hit http://q4os.org jessie/main amd64 Packages
Hit http://q4os.org jessie/main i386 Packages
Get:6 http://ftp.debian.org jessie-updates/non-free amd64 Packages/DiffIndex [736 B]
Get:7 http://ftp.debian.org jessie-updates/main i386 Packages/DiffIndex [6,916 B]
Get:8 http://ftp.debian.org jessie-updates/contrib i386 Packages [32 B]
Get:9 http://ftp.debian.org jessie-updates/non-free i386 Packages/DiffIndex [736 B]
Get:10 http://ftp.debian.org jessie-updates/contrib Translation-en [14 B]
Get:11 http://security.debian.org jessie/updates/main amd64 Packages [344 kB]
Get:12 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2,704 B]
Get:13 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Get:14 http://ftp.debian.org jessie-backports/main amd64 Packages/DiffIndex [27.8 kB]
Get:15 http://ftp.debian.org jessie-backports/contrib amd64 Packages/DiffIndex [22.8 kB]
Get:16 http://ftp.debian.org jessie-backports/non-free amd64 Packages/DiffIndex [17.4 kB]
Get:17 http://ftp.debian.org jessie-backports/main i386 Packages/DiffIndex [27.8 kB]
Get:18 http://ftp.debian.org jessie-backports/contrib i386 Packages/DiffIndex [23.3 kB]
Get:19 http://ftp.debian.org jessie-backports/non-free i386 Packages/DiffIndex [16.8 kB]
Get:20 http://ftp.debian.org jessie-backports/contrib Translation-en/DiffIndex [6,484 B]
Get:21 http://ftp.debian.org jessie-backports/main Translation-en/DiffIndex [27.8 kB]
Get:22 http://security.debian.org jessie/updates/contrib amd64 Packages [2,506 B]
Get:23 http://ftp.debian.org jessie-backports/non-free Translation-en/DiffIndex [14.2 kB]
Get:24 http://ftp.debian.org jessie-backports/main amd64 2017-01-27-1422.49.pdiff [6,768 B]
Hit http://ftp.debian.org jessie/main amd64 Packages
Hit http://ftp.debian.org jessie/contrib amd64 Packages
Get:25 http://security.debian.org jessie/updates/non-free amd64 Packages [14 B]
Get:26 http://security.debian.org jessie/updates/main i386 Packages [344 kB]
Hit http://ftp.debian.org jessie/non-free amd64 Packages
Hit http://ftp.debian.org jessie/main i386 Packages
Hit http://ftp.debian.org jessie/contrib i386 Packages
Hit http://ftp.debian.org jessie/non-free i386 Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Get:27 http://ftp.debian.org jessie-backports/main amd64 2017-01-27-1422.49.pdiff [6,768 B]
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Get:28 http://security.debian.org jessie/updates/contrib i386 Packages [2,526 B]
Get:29 http://security.debian.org jessie/updates/non-free i386 Packages [14 B]
Get:30 http://security.debian.org jessie/updates/contrib Translation-en [1,211 B]
Get:31 http://security.debian.org jessie/updates/main Translation-en [181 kB]
Ign http://q4os.org q4os-1-0-cn/main Translation-en_GB
Get:32 http://security.debian.org jessie/updates/non-free Translation-en [14 B]
Ign http://q4os.org jessie/main Translation-en_GB
Fetched 1,460 kB in 6s (211 kB/s)
Reading package lists... Done
And I see no mention of https so I would guess it is the google site that requires it. I have noticed that apt-transport-https is installed on my system though, so it might be that it is just used behind the scenes without me knowing about it.
The requirements for the package seem quite small though, so if you cannot install it by conventional means then try downloading the .deb package direct from debian and then install with sudo dpkg -i apt-transport-https_1.0.9.8.4_amd64.deb (for the 64 bit version) remember to change to the directory that contains the deb file first.
#4 2017-01-28 02:43
Hmmm, maybe only certain mirrors are set for https then.  I know on some of my debian systems it uses https, I assumed that it was the default nowadays.
#5 2017-01-28 06:23
Given that Google are pushing heavily to identify all non HTTPS web sites to visitors as 'not secure' it makes perfect sense that their own d/l site would require https. Seamonkey via Sourceforge also requires https. Hopefully other sites will follow.
Having said that, things have been quiet in update land recently. Interesting that FF 51.0 was swiftly followed by ssl update and FF 51.01.....
#6 2017-01-28 09:41
@gurdonark
Please run in terminal:
$ reportq4
and attach generated debug file here, or send it via email support@q4os.org for us to analyze it.
#7 2017-01-28 14:29
gurdonark
@Q4OS Team:
Thank you.
I attach the resulting file.
qreport.tar.gz
#8 2017-01-28 14:55
You have a non-standard entry in your sources list:
deb https://security.debian.org/ jessie/updates main non-free contrib
it should be:
deb http://security.debian.org/ jessie/updates main non-free contrib
We would recommend you to edit the appropriate sources list file in '/etc/apt/sources.list.d/' directory, and fix it manually.
There is another possibly non-compatible repository in sources list:
deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt/ all main
#9 2017-01-28 15:50
gurdonark
@q4osteam
Thank you.
I edited:
sources.list.d
20_debian_jessie.list
to now read:
deb http://ftp.debian.org/debian/ jessie main contrib non-free
# deb-src http://ftp.debian.org/debian/ jessie non-free contrib main
# deb-src http://security.debian.org/ jessie/updates contrib non-free main
# jessie-updates, previously known as 'volatile'
deb http://ftp.debian.org/debian/ jessie-updates non-free contrib main
# deb-src http://ftp.debian.org/debian/ jessie-updates main contrib non-free
# deb http://ftp.debian.org/debian/ jessie-proposed-updates contrib non-free main
# deb-src http://ftp.debian.org/debian/ jessie-proposed-updates contrib non-free main
Now when I run sudo apt-get update I get:
#10 2017-01-29 14:22
We would need to get additional info. Please run in terminal and put output here:
$ cat /etc/apt/sources.list /etc/apt/sources.list.d/*.list | grep -i '^deb'
Then uninstall Google Chrome from the Software centre and run:
$ sudo apt-get update
Post all terminal messages back.
#11 2017-01-29 20:42
gurdonark
@q4osteam:
Thank you.
I ran the command
and got the result
deb http://downloads.sourceforge.net/projec … zilla/apt/ all main
deb http://q4os.org/q4repo/ q4os-1-0-cn main
deb http://q4os.org/qtderepo/ jessie main
deb http://ftp.debian.org/debian/ jessie-backports main contrib non-free
deb http://www.deb-multimedia.org/ jessie main non-free
deb http://repository.spotify.com/ stable non-free
I uninstalled Google Chrome from the package manager.
I ran $ sudo apt-get update
and this is the result:
#12 2017-01-29 21:19
Try to run following commands and post back the output:
$ sudo apt-get -o Dir::Etc::sourcelist="sources.list.d/10_q4os.list" -o Dir::Etc::sourceparts="-" --no-list-cleanup update
$ apt-config dump
In addition you could edit respective files in '/etc/apt/sources.list.d/' and temporarily comment out following lines:
so they will look like this:
#deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt/ all main
#deb http://repository.spotify.com/ stable non-free
then run:
and post output here as well.
#13 2017-01-29 22:20
gurdonark
@q4osteam. Thank you.
I uninstalled Spotify after I had trouble editing the spotify entry (demanded password credentials to edit).
I ran sudo apt-get -o Dir::Etc::sourcelist="sources.list.d/10_q4os.list" -o Dir::Etc::sourceparts="-" --no-list-cleanup update
and got the result:
Ign http://q4os.org q4os-1-0-cn/main Translation-en_US
Then the updater offered me 7 updates, all Q4-Os system, and I successfully updated those.
When I run sudo apt-get update, I get:
Here are the results for  apt-config dump:
APT "";
APT::Architecture "amd64";
APT::Build-Essential "";
APT::Build-Essential:: "build-essential";
APT::Install-Recommends "true";
APT::Install-Suggests "0";
APT::Authentication "";
APT::Authentication::TrustCDROM "true";
APT::NeverAutoRemove "";
APT::NeverAutoRemove:: "^firmware-linux.*";
APT::NeverAutoRemove:: "^linux-firmware$";
APT::NeverAutoRemove:: "^linux-image-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-image-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^linux-headers-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-headers-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^linux-image-extra-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-image-extra-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^linux-signed-image-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-signed-image-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^kfreebsd-image-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^kfreebsd-image-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^kfreebsd-headers-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^kfreebsd-headers-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^gnumach-image-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^gnumach-image-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^.*-modules-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^.*-modules-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^.*-kernel-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^.*-kernel-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^linux-backports-modules-.*-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-backports-modules-.*-4\.7\.0-0\.bpo\.1-amd64$";
APT::NeverAutoRemove:: "^linux-tools-3\.16\.0-4-amd64$";
APT::NeverAutoRemove:: "^linux-tools-4\.7\.0-0\.bpo\.1-amd64$";
APT::VersionedKernelPackages "";
APT::VersionedKernelPackages:: "linux-image";
APT::VersionedKernelPackages:: "linux-headers";
APT::VersionedKernelPackages:: "linux-image-extra";
APT::VersionedKernelPackages:: "linux-signed-image";
APT::VersionedKernelPackages:: "kfreebsd-image";
APT::VersionedKernelPackages:: "kfreebsd-headers";
APT::VersionedKernelPackages:: "gnumach-image";
APT::VersionedKernelPackages:: ".*-modules";
APT::VersionedKernelPackages:: ".*-kernel";
APT::VersionedKernelPackages:: "linux-backports-modules-.*";
APT::VersionedKernelPackages:: "linux-tools";
APT::Never-MarkAuto-Sections "";
APT::Never-MarkAuto-Sections:: "metapackages";
APT::Never-MarkAuto-Sections:: "restricted/metapackages";
APT::Never-MarkAuto-Sections:: "universe/metapackages";
APT::Never-MarkAuto-Sections:: "multiverse/metapackages";
APT::Never-MarkAuto-Sections:: "oldlibs";
APT::Never-MarkAuto-Sections:: "restricted/oldlibs";
APT::Never-MarkAuto-Sections:: "universe/oldlibs";
APT::Never-MarkAuto-Sections:: "multiverse/oldlibs";
APT::Periodic "";
APT::Periodic::Update-Package-Lists "1";
APT::Periodic::Download-Upgradeable-Packages "0";
APT::Periodic::AutocleanInterval "0";
APT::Periodic::MaxAge "30";
APT::Periodic::MinAge "2";
APT::Periodic::MaxSize "500";
APT::Periodic::Unattended-Upgrade "0";
APT::Update "";
APT::Update::Post-Invoke "";
APT::Update::Post-Invoke:: "touch /var/lib/apt/periodic/update-success-stamp 2>/dev/null || true";
APT::Update::Post-Invoke-Success "";
APT::Update::Post-Invoke-Success:: "/usr/bin/test -e /usr/share/dbus-1/system-services/org.freedesktop.PackageKit.service && /usr/bin/test -S /var/run/dbus/system_bus_socket && /usr/bin/gdbus call --system --dest org.freedesktop.PackageKit --object-path /org/freedesktop/PackageKit --timeout 4 --method org.freedesktop.PackageKit.StateHasChanged cache-update > /dev/null; /bin/echo > /dev/null";
APT::Architectures "";
APT::Architectures:: "amd64";
APT::Architectures:: "i386";
APT::Compressor "";
APT::Compressor::. "";
APT::Compressor::.::Name ".";
APT::Compressor::.::Extension "";
APT::Compressor::.::Binary "";
APT::Compressor::.::Cost "1";
APT::Compressor::gzip "";
APT::Compressor::gzip::Name "gzip";
APT::Compressor::gzip::Extension ".gz";
APT::Compressor::gzip::Binary "gzip";
APT::Compressor::gzip::Cost "2";
APT::Compressor::gzip::CompressArg "";
APT::Compressor::gzip::CompressArg:: "-9n";
APT::Compressor::gzip::UncompressArg "";
APT::Compressor::gzip::UncompressArg:: "-d";
APT::Compressor::bzip2 "";
APT::Compressor::bzip2::Name "bzip2";
APT::Compressor::bzip2::Extension ".bz2";
APT::Compressor::bzip2::Binary "bzip2";
APT::Compressor::bzip2::Cost "3";
APT::Compressor::bzip2::CompressArg "";
APT::Compressor::bzip2::CompressArg:: "-9";
APT::Compressor::bzip2::UncompressArg "";
APT::Compressor::bzip2::UncompressArg:: "-d";
APT::Compressor::xz "";
APT::Compressor::xz::Name "xz";
APT::Compressor::xz::Extension ".xz";
APT::Compressor::xz::Binary "xz";
APT::Compressor::xz::Cost "4";
APT::Compressor::xz::CompressArg "";
APT::Compressor::xz::CompressArg:: "-6";
APT::Compressor::xz::UncompressArg "";
APT::Compressor::xz::UncompressArg:: "-d";
APT::Compressor::lzma "";
APT::Compressor::lzma::Name "lzma";
APT::Compressor::lzma::Extension ".lzma";
APT::Compressor::lzma::Binary "xz";
APT::Compressor::lzma::Cost "5";
APT::Compressor::lzma::CompressArg "";
APT::Compressor::lzma::CompressArg:: "--format=lzma";
APT::Compressor::lzma::CompressArg:: "-9";
APT::Compressor::lzma::UncompressArg "";
APT::Compressor::lzma::UncompressArg:: "--format=lzma";
APT::Compressor::lzma::UncompressArg:: "-d";
Dir "/";
Dir::State "var/lib/apt/";
Dir::State::lists "lists/";
Dir::State::cdroms "cdroms.list";
Dir::State::mirrors "mirrors/";
Dir::State::extended_states "extended_states";
Dir::State::status "/var/lib/dpkg/status";
Dir::Cache "var/cache/apt/";
Dir::Cache::archives "archives/";
Dir::Cache::srcpkgcache "srcpkgcache.bin";
Dir::Cache::pkgcache "pkgcache.bin";
Dir::Etc "etc/apt/";
Dir::Etc::sourcelist "sources.list";
Dir::Etc::sourceparts "sources.list.d";
Dir::Etc::vendorlist "vendors.list";
Dir::Etc::vendorparts "vendors.list.d";
Dir::Etc::main "apt.conf";
Dir::Etc::netrc "auth.conf";
Dir::Etc::parts "apt.conf.d";
Dir::Etc::preferences "preferences";
Dir::Etc::preferencesparts "preferences.d";
Dir::Etc::trusted "trusted.gpg";
Dir::Etc::trustedparts "trusted.gpg.d";
Dir::Bin "";
Dir::Bin::methods "/usr/lib/apt/methods";
Dir::Bin::solvers "";
Dir::Bin::solvers:: "/usr/lib/apt/solvers";
Dir::Bin::dpkg "/usr/bin/dpkg";
Dir::Bin::bzip2 "/bin/bzip2";
Dir::Bin::xz "/usr/bin/xz";
Dir::Bin::lzma "/usr/bin/xz";
Dir::Media "";
Dir::Media::MountPath "/media/cdrom";
Dir::Log "var/log/apt";
Dir::Log::Terminal "term.log";
Dir::Log::History "history.log";
Dir::Ignore-Files-Silently "";
Dir::Ignore-Files-Silently:: "~$";
Dir::Ignore-Files-Silently:: "\.disabled$";
Dir::Ignore-Files-Silently:: "\.bak$";
Dir::Ignore-Files-Silently:: "\.dpkg-[a-z]+$";
Dir::Ignore-Files-Silently:: "\.save$";
Dir::Ignore-Files-Silently:: "\.orig$";
Dir::Ignore-Files-Silently:: "\.distUpgrade$";
Acquire "";
Acquire::cdrom "";
Acquire::cdrom::mount "/media/cdrom";
Acquire::Languages "";
Acquire::Languages:: "en_US";
Acquire::Languages:: "en";
Acquire::Languages:: "none";
Aptitude "";
Aptitude::Get-Root-Command "sudo:/usr/bin/sudo";
DPkg "";
DPkg::Post-Invoke "";
DPkg::Post-Invoke:: "/usr/bin/test -e /usr/share/dbus-1/system-services/org.freedesktop.PackageKit.service && /usr/bin/test -S /var/run/dbus/system_bus_socket && /usr/bin/gdbus call --system --dest org.freedesktop.PackageKit --object-path /org/freedesktop/PackageKit --timeout 4 --method org.freedesktop.PackageKit.StateHasChanged cache-update > /dev/null; /bin/echo > /dev/null";
DPkg::Pre-Install-Pkgs "";
DPkg::Pre-Install-Pkgs:: "/usr/sbin/dpkg-preconfigure --apt || true";
Unattended-Upgrade "";
Unattended-Upgrade::Origins-Pattern "";
Unattended-Upgrade::Origins-Pattern:: "origin=Debian,codename=${distro_codename},label=Debian-Security";
Unattended-Upgrade::Origins-Pattern:: "o=Unofficial Multimedia Packages,a=stable,n=jessie,l=Unofficial Multimedia Packages";
Unattended-Upgrade::Origins-Pattern:: "o=q4os.org,n=q4os-1-0-cn";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,n=jessie";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,n=jessie-updates";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,n=jessie-proposed-updates";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,n=jessie,l=Debian-Security";
Unattended-Upgrade::Origins-Pattern:: "o=Debian Backports,n=jessie-backports";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,a=stable";
Unattended-Upgrade::Origins-Pattern:: "o=Debian,a=stable-updates";
CommandLine "";
CommandLine::AsString "apt-config dump";
adminq@q4os-desktop:~$
Thank you for all your help so far.
#14 2017-01-29 22:33
Now, edit respective files in '/etc/apt/sources.list.d/' directory and temporarily comment out following lines:
Then run:
$ qrepolist
and post output here.
#15 2017-01-30 03:38
gurdonark
@Q4OSteam
Thank you.
Here is the output to adminq@q4os-desktop:~$ sudo qrepolist
and here is the output to sudo apt-get update:
sudo apt-get update
Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
Get:2 http://security.debian.org jessie/updates/main amd64 Packages [345 kB]
Get:3 http://www.deb-multimedia.org jessie InRelease [38.2 kB]
Get:4 http://ftp.debian.org jessie-updates InRelease [145 kB]
Get:5 http://security.debian.org jessie/updates/non-free amd64 Packages [14 B]
Get:6 http://security.debian.org jessie/updates/contrib amd64 Packages [2,506 B]
Get:7 http://security.debian.org jessie/updates/main i386 Packages [345 kB]
Get:8 http://www.deb-multimedia.org jessie/main amd64 Packages [119 kB]
Get:9 http://security.debian.org jessie/updates/non-free i386 Packages [14 B]
Get:10 http://security.debian.org jessie/updates/contrib i386 Packages [2,526 B]
Get:11 http://security.debian.org jessie/updates/contrib Translation-en [1,211 B]
Get:12 http://security.debian.org jessie/updates/main Translation-en [182 kB]
Get:13 http://www.deb-multimedia.org jessie/non-free amd64 Packages [2,128 B]
Get:14 http://ftp.debian.org jessie-backports InRelease [166 kB]
Get:15 http://security.debian.org jessie/updates/non-free Translation-en [14 B]
Get:16 http://www.deb-multimedia.org jessie/main i386 Packages [119 kB]
Get:17 http://www.deb-multimedia.org jessie/non-free i386 Packages [4,920 B]
Get:18 http://ftp.debian.org jessie Release.gpg [2,373 B]
Get:19 http://ftp.debian.org jessie-updates/non-free amd64 Packages/DiffIndex [736 B]
Hit http://www.deb-multimedia.org jessie/main Translation-en
Get:20 http://ftp.debian.org jessie-updates/contrib amd64 Packages [32 B]
Hit http://www.deb-multimedia.org jessie/non-free Translation-en
Get:21 http://ftp.debian.org jessie-updates/main amd64 Packages/DiffIndex [6,916 B]
Get:22 http://ftp.debian.org jessie-updates/non-free i386 Packages/DiffIndex [736 B]
Get:23 http://ftp.debian.org jessie-updates/contrib i386 Packages [32 B]
Get:24 http://ftp.debian.org jessie-updates/main i386 Packages/DiffIndex [6,916 B]
Get:25 http://ftp.debian.org jessie-updates/contrib Translation-en [14 B]
Get:26 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2,704 B]
Get:27 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Get:28 http://ftp.debian.org jessie-backports/main amd64 Packages/DiffIndex [27.8 kB]
Get:29 http://ftp.debian.org jessie-backports/contrib amd64 Packages/DiffIndex [22.8 kB]
Get:30 http://ftp.debian.org jessie-backports/non-free amd64 Packages/DiffIndex [17.4 kB]
Get:31 http://ftp.debian.org jessie-backports/main i386 Packages/DiffIndex [27.8 kB]
Get:32 http://ftp.debian.org jessie-backports/contrib i386 Packages/DiffIndex [23.3 kB]
Get:33 http://ftp.debian.org jessie-backports/non-free i386 Packages/DiffIndex [16.8 kB]
Get:34 http://ftp.debian.org jessie-backports/contrib Translation-en/DiffIndex [6,484 B]
Get:35 http://ftp.debian.org jessie-backports/main Translation-en/DiffIndex [27.8 kB]
Get:36 http://ftp.debian.org jessie-backports/non-free Translation-en/DiffIndex [14.2 kB]
Get:37 http://ftp.debian.org jessie Release [148 kB]
Get:38 http://ftp.debian.org jessie-backports/contrib amd64 2016-12-07-2027.24.pdiff [325 B]
Get:39 http://ftp.debian.org jessie-backports/contrib amd64 2016-12-18-2027.48.pdiff [408 B]
Get:40 http://ftp.debian.org jessie-backports/contrib amd64 2016-12-27-0827.59.pdiff [1,583 B]
Get:41 http://ftp.debian.org jessie-backports/contrib amd64 2017-01-19-0225.55.pdiff [442 B]
Get:42 http://ftp.debian.org jessie-backports/contrib amd64 2017-01-24-2023.00.pdiff [246 B]
Get:43 http://ftp.debian.org jessie-backports/contrib amd64 2017-01-24-2023.00.pdiff [246 B]
Get:44 http://ftp.debian.org jessie-backports/non-free amd64 2017-01-02-1429.18.pdiff [3,770 B]
Get:45 http://ftp.debian.org jessie-backports/non-free amd64 2017-01-02-2030.43.pdiff [4,703 B]
Get:46 http://ftp.debian.org jessie-backports/non-free amd64 2017-01-09-2028.55.pdiff [8,138 B]
Get:47 http://ftp.debian.org jessie-backports/non-free amd64 2017-01-15-1426.26.pdiff [3,067 B]
Get:48 http://ftp.debian.org jessie-backports/non-free amd64 2017-01-15-1426.26.pdiff [3,067 B]
Ign http://q4os.org jessie/main Translation-en_US
Get:49 http://ftp.debian.org jessie-backports/contrib i386 2016-12-07-2027.24.pdiff [325 B]
Get:50 http://ftp.debian.org jessie-backports/contrib i386 2016-12-18-2027.48.pdiff [407 B]
Get:51 http://ftp.debian.org jessie-backports/contrib i386 2016-12-27-1428.13.pdiff [1,568 B]
Get:52 http://ftp.debian.org jessie-backports/contrib i386 2017-01-19-0225.55.pdiff [441 B]
Get:53 http://ftp.debian.org jessie-backports/contrib i386 2017-01-24-2023.00.pdiff [247 B]
Get:54 http://ftp.debian.org jessie-backports/contrib i386 2017-01-24-2023.00.pdiff [247 B]
Get:55 http://ftp.debian.org jessie-backports/non-free i386 2017-01-02-1429.18.pdiff [3,964 B]
Get:56 http://ftp.debian.org jessie-backports/non-free i386 2017-01-02-2030.43.pdiff [5,025 B]
Get:57 http://ftp.debian.org jessie-backports/non-free i386 2017-01-09-2028.55.pdiff [8,391 B]
Get:58 http://ftp.debian.org jessie-backports/non-free i386 2017-01-15-1426.26.pdiff [3,064 B]
Get:59 http://ftp.debian.org jessie-backports/non-free i386 2017-01-15-1426.26.pdiff [3,064 B]
Get:60 http://ftp.debian.org jessie-backports/main 2016-12-07-2027.24.pdiff [542 B]
Get:61 http://ftp.debian.org jessie-backports/main 2016-12-09-2028.43.pdiff [59 B]
Get:62 http://ftp.debian.org jessie-backports/main 2016-12-10-1427.03.pdiff [33 B]
Get:63 http://ftp.debian.org jessie-backports/main 2016-12-12-1427.31.pdiff [315 B]
Get:64 http://ftp.debian.org jessie-backports/main 2016-12-16-1427.28.pdiff [3,088 B]
Get:65 http://ftp.debian.org jessie-backports/main 2016-12-16-2027.34.pdiff [2,475 B]
Get:66 http://ftp.debian.org jessie-backports/main 2016-12-17-0228.07.pdiff [970 B]
Get:67 http://ftp.debian.org jessie-backports/main 2016-12-19-2028.01.pdiff [42 B]
Get:68 http://ftp.debian.org jessie-backports/main 2016-12-20-1427.50.pdiff [1,816 B]
Get:69 http://ftp.debian.org jessie-backports/main 2016-12-20-2027.47.pdiff [1,778 B]
Get:70 http://ftp.debian.org jessie-backports/main 2016-12-21-0227.48.pdiff [324 B]
Get:71 http://ftp.debian.org jessie-backports/main 2016-12-27-1428.13.pdiff [3,655 B]
Get:72 http://ftp.debian.org jessie-backports/main 2016-12-27-2028.19.pdiff [33 B]
Get:73 http://ftp.debian.org jessie-backports/main 2016-12-30-0828.20.pdiff [136 B]
Get:74 http://ftp.debian.org jessie-backports/main 2017-01-02-0229.07.pdiff [271 B]
Get:75 http://ftp.debian.org jessie-backports/main 2017-01-02-1429.18.pdiff [289 B]
Get:76 http://ftp.debian.org jessie-backports/main 2017-01-06-0828.56.pdiff [206 B]
Get:77 http://ftp.debian.org jessie-backports/main 2017-01-09-2028.55.pdiff [9,175 B]
Get:78 http://ftp.debian.org jessie-backports/main 2017-01-11-2032.12.pdiff [294 B]
Get:79 http://ftp.debian.org jessie-backports/main 2017-01-12-1428.40.pdiff [205 B]
Get:80 http://ftp.debian.org jessie-backports/main 2017-01-14-1513.37.pdiff [397 B]
Get:81 http://ftp.debian.org jessie-backports/main 2017-01-14-2042.37.pdiff [41 B]
Get:82 http://ftp.debian.org jessie-backports/main 2017-01-16-1425.40.pdiff [33 B]
Get:83 http://ftp.debian.org jessie-backports/main 2017-01-21-1422.59.pdiff [11.7 kB]
Get:84 http://ftp.debian.org jessie-backports/main 2017-01-21-2023.34.pdiff [841 B]
Get:85 http://ftp.debian.org jessie-backports/main 2017-01-23-1423.26.pdiff [791 B]
Get:86 http://ftp.debian.org jessie-backports/main 2017-01-29-0825.11.pdiff [31 B]
Get:87 http://ftp.debian.org jessie-backports/main 2017-01-29-0825.11.pdiff [31 B]
Get:88 http://ftp.debian.org jessie-backports/non-free 2017-01-02-1429.18.pdiff [1,068 B]
Get:89 http://ftp.debian.org jessie-backports/non-free 2017-01-02-2030.43.pdiff [1,306 B]
Get:90 http://ftp.debian.org jessie-backports/non-free 2017-01-09-2028.55.pdiff [1,576 B]
Get:91 http://ftp.debian.org jessie-backports/non-free 2017-01-15-1426.26.pdiff [2,073 B]
Get:92 http://ftp.debian.org jessie-backports/non-free 2017-01-15-1426.26.pdiff [2,073 B]
Get:93 http://ftp.debian.org jessie/main amd64 Packages [6,776 kB]
Get:94 http://ftp.debian.org jessie/contrib amd64 Packages [50.2 kB]
Get:95 http://ftp.debian.org jessie/non-free amd64 Packages [83.6 kB]
Get:96 http://ftp.debian.org jessie/main i386 Packages [6,779 kB]
Get:97 http://ftp.debian.org jessie/contrib i386 Packages [49.5 kB]
Get:98 http://ftp.debian.org jessie/non-free i386 Packages [80.4 kB]
Get:99 http://ftp.debian.org jessie/contrib Translation-en [38.5 kB]
Get:100 http://ftp.debian.org jessie/main Translation-en [4,582 kB]
Get:101 http://ftp.debian.org jessie/non-free Translation-en [72.1 kB]
Get:102 http://ftp.debian.org jessie-backports/main amd64 Packages [791 kB]
Get:103 http://ftp.debian.org jessie-backports/main i386 Packages [778 kB]
Fetched 22.0 MB in 29s (747 kB/s)
#16 2017-01-30 03:56
gurdonark
Good news! I just ran synaptic and was able to do an extensive update.
The search cat /etc/*_version brings the pleasing result:
8.7
1.8.2-n1
Thank you for your help.
Should I now edit the spotify and mozilla sources again to remove the #? Are there other steps I should take?
#17 2017-01-30 10:37
Well, glad to see such result smile  Now, you should take the following steps:
1.Full system upgrade
  $ sudo apt-get dist-upgrade
2. Upgrade the 'backports' kernel - important !
  $ sudo apt-get purge rtkit
  $ qinst-kernel-bpo
  $ reboot
3. Install Google Chrome again from Q4OS Software Centre
4. Do not edit former 'Spotify' repository manually, you should remove the respective '.list' file completely. Add Q4OS default 'Spotify' repositories and keyring instead:
  $ sudo qrepoadd spotify
5. Edit and revert the Ubuntuzilla sources again manually removing the '#' character, install 'apt-transport-https' package and update the system once more:
  $ sudo apt-get install apt-transport-https
#18 2017-01-30 19:00
In addition, we would recommend you to install Firefox and Thunderbird from Q4OS Software Centre, instead of using the Ubuntuzilla repositories. It's much easier as well as cleaner way.
