Greetings, all! I hope someone can point me in the right direction here, as I try to install ffmpeg on my Lenovo T61, running Orion 1.84 (X64).
When I do sudo apt-get install ffmpeg, I get this:
ffmpeg : Depends: libavcodec56 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
Depends: libavdevice56 (>= 10:2.6.9) but it is not going to be installed
Depends: libavfilter5 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
Depends: libavformat56 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
Depends: libavresample2 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
Depends: libavutil54 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
Depends: libpostproc53 (>= 10:2.6.9) but it is not going to be installed
Depends: libswresample1 (>= 10:2.6.9) but it is not going to be installed
Depends: libswscale3 (>= 10:2.6.9) but 6:11.8-1~deb8u1 is to be installed
E: Unable to correct problems, you have held broken packages.Any ideas as to how I can move forward and get ffmpeg installed on my system?
David.
Current setup: Acer Aspire One D257 / Q4OS 6.10
You could try this one:
$ sudo apt-get -t jessie install ffmpeg
and report back
Hey, it worked! Thank you very much, Team Q4OS!
