on new msi cubi n-031xde the desktop is in right resolution (1920x1080) with q4os-live-1.8.1-x64 but after doing the UEFI install there is only 1024x768 available to display. So what is wrong here. look like the grafic-driver is not installed. any idea what i can do?
i already did
sudo apt-get update
sudo apt-get dist-upgrade
First, you could try to install the 'Basic' profile from SW Profiler. We will investigate a bit and post some more info here as soon as possible.
EDIT: Would be helpful to post both '/var/log/Xorg.0.log' files from live-cd as well as from the target system here or send it via support@q4os.org
EDIT2: Did you try to configure resolution using 'tderandrtray' applet ?
ok, install the 'Basic' profile doesn't help and using 'tderandrtray' ether.
Exciting, after install i can not start live-cd again to get '/var/log/Xorg.0.log' files from live-cd, because i have to start a windows software ;-) to reach BIOS.
MSI® HOW-TO enter BIOS with GO2BIOS : https://www.youtube.com/watch?v=-tNjrwd2TiI
may this is enough '/var/log/Xorg.0.log' from running system:
[ 3.090]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 3.090] X Protocol Version 11, Revision 0
[ 3.090] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 3.090] Current Operating System: Linux q4os-desktop 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64
[ 3.090] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=fa30e211-12b3-4ca8-9601-6b7741a860bf ro quiet loglevel=3 TERM=dumb
[ 3.090] Build Date: 11 February 2015 12:32:02AM
[ 3.090] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 3.090] Current version of pixman: 0.32.6
[ 3.090] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3.090] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.090] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 1 10:43:00 2016
[ 3.095] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.095] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.126] (==) No Layout section. Using the first Screen section.
[ 3.126] (==) No screen section available. Using defaults.
[ 3.126] (**) |-->Screen "Default Screen Section" (0)
[ 3.126] (**) | |-->Monitor "<default monitor>"
[ 3.239] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 3.239] (==) Automatically adding devices
[ 3.239] (==) Automatically enabling devices
[ 3.239] (==) Automatically adding GPU devices
[ 3.239] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[ 3.239] Entry deleted from font path.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 3.239] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 3.239] (==) FontPath set to:
built-ins
[ 3.239] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.239] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3.239] (II) Loader magic: 0x7fee6e3a8d80
[ 3.239] (II) Module ABI versions:
[ 3.239] X.Org ANSI C Emulation: 0.4
[ 3.239] X.Org Video Driver: 18.0
[ 3.239] X.Org XInput driver : 21.0
[ 3.239] X.Org Server Extension : 8.0
[ 3.241] (--) PCI:*(0:0:2:0) 8086:22b1:1462:b120 rev 53, Mem @ 0x80000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64
[ 3.241] (II) LoadModule: "glx"
[ 3.241] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.243] (II) Module glx: vendor="X.Org Foundation"
[ 3.243] compiled for 1.16.4, module version = 1.0.0
[ 3.243] ABI class: X.Org Server Extension, version 8.0
[ 3.243] (==) AIGLX enabled
[ 3.243] (==) Matched intel as autoconfigured driver 0
[ 3.243] (==) Matched modesetting as autoconfigured driver 1
[ 3.243] (==) Matched fbdev as autoconfigured driver 2
[ 3.243] (==) Matched vesa as autoconfigured driver 3
[ 3.243] (==) Assigned the driver to the xf86ConfigLayout
[ 3.243] (II) LoadModule: "intel"
[ 3.260] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3.260] (II) Module intel: vendor="X.Org Foundation"
[ 3.260] compiled for 1.15.99.904, module version = 2.21.15
[ 3.260] Module class: X.Org Video Driver
[ 3.261] ABI class: X.Org Video Driver, version 18.0
[ 3.261] (II) LoadModule: "modesetting"
[ 3.261] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.261] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.261] compiled for 1.16.4, module version = 0.9.0
[ 3.261] Module class: X.Org Video Driver
[ 3.261] (II) LoadModule: "fbdev"
[ 3.261] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 3.261] (II) Module fbdev: vendor="X.Org Foundation"
[ 3.261] compiled for 1.15.99.904, module version = 0.4.4
[ 3.261] (II) LoadModule: "vesa"
[ 3.261] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 3.296] (II) Module vesa: vendor="X.Org Foundation"
[ 3.296] compiled for 1.15.99.904, module version = 2.3.3
[ 3.296] Module class: X.Org Video Driver
[ 3.296] ABI class: X.Org Video Driver, version 18.0
[ 3.296] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
HD Graphics 5000, HD Graphics P4600/P4700, Iris(TM) Graphics 5100,
HD Graphics 4400, HD Graphics 4200, Iris(TM) Pro Graphics 5200
[ 3.296] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.296] (II) FBDEV: driver for framebuffer: fbdev
[ 3.296] (II) VESA: driver for VESA chipsets: vesa
[ 3.296] (++) using VT number 7
[ 3.310] (EE) open /dev/dri/card0: No such file or directory
[ 3.310] (WW) Falling back to old probe method for modesetting
[ 3.310] (II) Loading sub module "fbdevhw"
[ 3.310] (II) LoadModule: "fbdevhw"
[ 3.311] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 3.311] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 3.311] compiled for 1.16.4, module version = 0.0.2
[ 3.311] ABI class: X.Org Video Driver, version 18.0
[ 3.311] (**) FBDEV(1): claimed PCI slot 0@0:2:0
[ 3.311] (II) FBDEV(1): using default device
[ 3.311] (WW) Falling back to old probe method for vesa
[ 3.311] (EE) Screen 0 deleted because of no matching config section.
[ 3.311] (II) UnloadModule: "modesetting"
[ 3.311] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 3.311] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 3.311] (==) FBDEV(0): RGB weight 888
[ 3.311] (==) FBDEV(0): Default visual is TrueColor
[ 3.311] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.311] (II) FBDEV(0): hardware: simple (video memory: 3072kB)
[ 3.311] (II) FBDEV(0): checking modes against framebuffer device...
[ 3.311] (II) FBDEV(0): checking modes against monitor...
[ 3.311] (--) FBDEV(0): Virtual size is 1024x768 (pitch 1024)
[ 3.311] (**) FBDEV(0): Built-in mode "current"
[ 3.311] (++) FBDEV(0): DPI set to (96, 96)
[ 3.311] (II) Loading sub module "fb"
[ 3.311] (II) LoadModule: "fb"
[ 3.311] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.312] (II) Module fb: vendor="X.Org Foundation"
[ 3.312] compiled for 1.16.4, module version = 1.0.0
[ 3.312] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.312] (**) FBDEV(0): using shadow framebuffer
[ 3.312] (II) Loading sub module "shadow"
[ 3.312] (II) LoadModule: "shadow"
[ 3.312] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 3.312] (II) Module shadow: vendor="X.Org Foundation"
[ 3.312] compiled for 1.16.4, module version = 1.1.0
[ 3.312] (II) UnloadModule: "vesa"
[ 3.312] (II) Unloading vesa
[ 3.312] (==) Depth 24 pixmap format is 32 bpp
[ 3.312] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 3.312] (==) FBDEV(0): Backing store enabled
[ 3.313] (==) FBDEV(0): DPMS enabled
[ 3.313] (==) RandR enabled
[ 3.321] (II) SELinux: Disabled on system
[ 3.322] (II) AIGLX: Screen 0 is not DRI2 capable
[ 3.322] (EE) AIGLX: reverting to software rendering
[ 3.386] (II) AIGLX: Loaded and initialized swrast
[ 3.386] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 3.448] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 3.448] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3.448] (II) LoadModule: "evdev"
[ 3.448] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3.449] (II) Module evdev: vendor="X.Org Foundation"
[ 3.449] compiled for 1.16.0, module version = 2.9.0
[ 3.449] Module class: X.Org XInput Driver
[ 3.449] ABI class: X.Org XInput driver, version 21.0
[ 3.449] (II) Using input driver 'evdev' for 'Power Button'
[ 3.449] (**) Power Button: always reports core events
[ 3.449] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 3.449] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 3.449] (--) evdev: Power Button: Found keys
[ 3.449] (II) evdev: Power Button: Configuring as keyboard
[ 3.449] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input8/event4"
[ 3.449] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3.449] (**) Option "xkb_rules" "evdev"
[ 3.449] (**) Option "xkb_model" "pc105"
[ 3.449] (**) Option "xkb_layout" "de"
[ 3.494] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[ 3.494] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 3.494] (II) Using input driver 'evdev' for 'Sleep Button'
[ 3.494] (**) Sleep Button: always reports core events
[ 3.494] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[ 3.494] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 3.494] (--) evdev: Sleep Button: Found keys
[ 3.494] (II) evdev: Sleep Button: Configuring as keyboard
[ 3.494] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input7/event3"
[ 3.494] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[ 3.494] (**) Option "xkb_rules" "evdev"
[ 3.494] (**) Option "xkb_model" "pc105"
[ 3.494] (**) Option "xkb_layout" "de"
[ 3.495] (II) config/udev: Adding input device wired keyboard (/dev/input/event0)
[ 3.495] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 3.495] (II) Using input driver 'evdev' for ' wired keyboard'
[ 3.495] (**) wired keyboard: always reports core events
[ 3.495] (**) evdev: wired keyboard: Device: "/dev/input/event0"
[ 3.495] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 3.495] (--) evdev: wired keyboard: Found keys
[ 3.495] (II) evdev: wired keyboard: Configuring as keyboard
[ 3.495] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:046A:0180.0001/input/input4/event0"
[ 3.495] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 8)
[ 3.495] (**) Option "xkb_rules" "evdev"
[ 3.495] (**) Option "xkb_model" "pc105"
[ 3.495] (**) Option "xkb_layout" "de"
[ 3.496] (II) config/udev: Adding input device wired keyboard (/dev/input/event1)
[ 3.496] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 3.496] (II) Using input driver 'evdev' for ' wired keyboard'
[ 3.496] (**) wired keyboard: always reports core events
[ 3.496] (**) evdev: wired keyboard: Device: "/dev/input/event1"
[ 3.497] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 3.497] (--) evdev: wired keyboard: Found 1 mouse buttons
[ 3.497] (--) evdev: wired keyboard: Found scroll wheel(s)
[ 3.497] (--) evdev: wired keyboard: Found relative axes
[ 3.497] (II) evdev: wired keyboard: Forcing relative x/y axes to exist.
[ 3.497] (--) evdev: wired keyboard: Found absolute axes
[ 3.497] (II) evdev: wired keyboard: Forcing absolute x/y axes to exist.
[ 3.497] (--) evdev: wired keyboard: Found keys
[ 3.497] (II) evdev: wired keyboard: Configuring as mouse
[ 3.497] (II) evdev: wired keyboard: Configuring as keyboard
[ 3.497] (II) evdev: wired keyboard: Adding scrollwheel support
[ 3.497] (**) evdev: wired keyboard: YAxisMapping: buttons 4 and 5
[ 3.497] (**) evdev: wired keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.497] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046A:0180.0002/input/input5/event1"
[ 3.497] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 9)
[ 3.497] (**) Option "xkb_rules" "evdev"
[ 3.497] (**) Option "xkb_model" "pc105"
[ 3.497] (**) Option "xkb_layout" "de"
[ 3.497] (II) evdev: wired keyboard: initialized for relative axes.
[ 3.497] (WW) evdev: wired keyboard: ignoring absolute axes.
[ 3.498] (**) wired keyboard: (accel) keeping acceleration scheme 1
[ 3.498] (**) wired keyboard: (accel) acceleration profile 0
[ 3.498] (**) wired keyboard: (accel) acceleration factor: 2.000
[ 3.498] (**) wired keyboard: (accel) acceleration threshold: 4
[ 3.498] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event2)
[ 3.498] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 3.498] (II) Using input driver 'evdev' for 'Logitech USB-PS/2 Optical Mouse'
[ 3.498] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[ 3.498] (**) evdev: Logitech USB-PS/2 Optical Mouse: Device: "/dev/input/event2"
[ 3.498] (--) evdev: Logitech USB-PS/2 Optical Mouse: Vendor 0x46d Product 0xc040
[ 3.498] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found 12 mouse buttons
[ 3.498] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
[ 3.498] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found relative axes
[ 3.498] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
[ 3.498] (II) evdev: Logitech USB-PS/2 Optical Mouse: Configuring as mouse
[ 3.498] (II) evdev: Logitech USB-PS/2 Optical Mouse: Adding scrollwheel support
[ 3.499] (**) evdev: Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
[ 3.499] (**) evdev: Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.499] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C040.0003/input/input6/event2"
[ 3.499] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 10)
[ 3.499] (II) evdev: Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
[ 3.499] (**) Logitech USB-PS/2 Optical Mouse: (accel) keeping acceleration scheme 1
[ 3.499] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration profile 0
[ 3.499] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[ 3.499] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[ 3.499] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[ 3.499] (II) No input driver specified, ignoring this device.
[ 3.500] (II) This device may have been added with another device file.
[ 3.500] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event7)
[ 3.500] (II) No input driver specified, ignoring this device.
[ 3.500] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[ 3.501] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event9)
[ 3.501] (II) No input driver specified, ignoring this device.
[ 3.501] (II) This device may have been added with another device file.
[ 3.501] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event10)
[ 3.502] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event11)
[ 3.502] (II) No input driver specified, ignoring this device.
[ 3.502] (II) This device may have been added with another device file.
[ 3.502] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 3.503] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event6)
[ 3.503] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 3.503] (II) Using input driver 'evdev' for 'MSI WMI hotkeys'
[ 3.503] (**) MSI WMI hotkeys: always reports core events
[ 3.503] (**) evdev: MSI WMI hotkeys: Device: "/dev/input/event6"
[ 3.503] (--) evdev: MSI WMI hotkeys: Vendor 0 Product 0
[ 3.503] (--) evdev: MSI WMI hotkeys: Found keys
[ 3.503] (II) evdev: MSI WMI hotkeys: Configuring as keyboard
[ 3.503] (**) Option "config_info" "udev:/sys/devices/virtual/input/input11/event6"
[ 3.503] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 11)
[ 3.503] (**) Option "xkb_rules" "evdev"
[ 3.503] (**) Option "xkb_model" "pc105"
[ 3.503] (**) Option "xkb_layout" "de"
[ 3.509] (EE) FBDEV(0): FBIOBLANK: Invalid argument
EDIT:
reset CMOS by removing garanty label and disconnect battery brings me back to BIOS ;-)
here log from liveCD
[ 23.204]
[ 23.204] X Protocol Version 11, Revision 0
[ 23.204] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 23.204] Current Operating System: Linux debian 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64
[ 23.204] Kernel command line: BOOT_IMAGE=/live/vmlinuz boot=live components quiet username=adminq
[ 23.204] Build Date: 11 February 2015 12:32:02AM
[ 23.204] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 23.204] Current version of pixman: 0.32.6
[ 23.204] Before reporting problems, check http://wiki.x.org
[ 23.204] Markers: (--) probed, (**) from config file, (==) default setting,
[ 23.204] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 1 00:27:03 2015
[ 23.249] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 23.249] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 23.268] (==) No Layout section. Using the first Screen section.
[ 23.268] (==) No screen section available. Using defaults.
[ 23.268] (**) |-->Screen "Default Screen Section" (0)
[ 23.268] (**) | |-->Monitor "<default monitor>"
[ 23.268] (==) No monitor specified for screen "Default Screen Section".
[ 23.268] (==) Automatically adding devices
[ 23.268] (==) Automatically enabling devices
[ 23.268] (==) Automatically adding GPU devices
[ 23.290] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 23.290] Entry deleted from font path.
[ 23.290] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 23.290] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 23.290] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 23.290] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 23.290] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 23.290] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 23.290] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 23.290] (II) The server relies on udev to provide the list of input devices.
[ 23.290] (II) Loader magic: 0x7f26b4fb9d80
[ 23.290] (II) Module ABI versions:
[ 23.290] X.Org ANSI C Emulation: 0.4
[ 23.290] X.Org Video Driver: 18.0
[ 23.290] X.Org XInput driver : 21.0
[ 23.290] X.Org Server Extension : 8.0
[ 23.292] (--) PCI:*(0:0:2:0) 8086:22b1:1462:b120 rev 53, Mem @ 0x80000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64
[ 23.292] (II) LoadModule: "glx"
[ 23.294] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.540] (II) Module glx: vendor="X.Org Foundation"
[ 23.540] compiled for 1.16.4, module version = 1.0.0
[ 23.540] ABI class: X.Org Server Extension, version 8.0
[ 23.540] (==) AIGLX enabled
[ 23.540] (==) Matched intel as autoconfigured driver 0
[ 23.540] (==) Matched modesetting as autoconfigured driver 1
[ 23.540] (==) Matched fbdev as autoconfigured driver 2
[ 23.540] (==) Matched vesa as autoconfigured driver 3
[ 23.540] (==) Assigned the driver to the xf86ConfigLayout
[ 23.540] (II) LoadModule: "intel"
[ 23.540] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 23.630] (II) Module intel: vendor="X.Org Foundation"
[ 23.630] compiled for 1.15.99.904, module version = 2.21.15
[ 23.630] Module class: X.Org Video Driver
[ 23.630] ABI class: X.Org Video Driver, version 18.0
[ 23.630] (II) LoadModule: "modesetting"
[ 23.630] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 23.651] (II) Module modesetting: vendor="X.Org Foundation"
[ 23.651] compiled for 1.16.4, module version = 0.9.0
[ 23.651] Module class: X.Org Video Driver
[ 23.651] ABI class: X.Org Video Driver, version 18.0
[ 23.651] (II) LoadModule: "fbdev"
[ 23.651] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 23.667] (II) Module fbdev: vendor="X.Org Foundation"
[ 23.667] compiled for 1.15.99.904, module version = 0.4.4
[ 23.667] Module class: X.Org Video Driver
[ 23.667] ABI class: X.Org Video Driver, version 18.0
[ 23.667] (II) LoadModule: "vesa"
[ 23.667] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 23.679] (II) Module vesa: vendor="X.Org Foundation"
[ 23.679] compiled for 1.15.99.904, module version = 2.3.3
[ 23.679] Module class: X.Org Video Driver
[ 23.679] ABI class: X.Org Video Driver, version 18.0
[ 23.680] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 23.680] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 23.680] (II) FBDEV: driver for framebuffer: fbdev
[ 23.680] (II) VESA: driver for VESA chipsets: vesa
[ 23.680] (++) using VT number 7
[ 23.697] (EE) open /dev/dri/card0: No such file or directory
[ 23.697] (WW) Falling back to old probe method for modesetting
[ 23.697] (II) Loading sub module "fbdevhw"
[ 23.697] (II) LoadModule: "fbdevhw"
[ 23.699] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 23.716] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 23.716] compiled for 1.16.4, module version = 0.0.2
[ 23.716] ABI class: X.Org Video Driver, version 18.0
[ 23.716] (**) FBDEV(1): claimed PCI slot 0@0:2:0
[ 23.716] (II) FBDEV(1): using default device
[ 23.716] (WW) Falling back to old probe method for vesa
[ 23.716] (EE) Screen 0 deleted because of no matching config section.
[ 23.716] (II) UnloadModule: "modesetting"
[ 23.716] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 23.716] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 23.716] (==) FBDEV(0): RGB weight 888
[ 23.716] (==) FBDEV(0): Default visual is TrueColor
[ 23.716] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 23.716] (II) FBDEV(0): hardware: simple (video memory: 8100kB)
[ 23.716] (II) FBDEV(0): checking modes against framebuffer device...
[ 23.716] (II) FBDEV(0): checking modes against monitor...
[ 23.716] (--) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 23.716] (**) FBDEV(0): Built-in mode "current"
[ 23.716] (++) FBDEV(0): DPI set to (96, 96)
[ 23.716] (II) Loading sub module "fb"
[ 23.716] (II) LoadModule: "fb"
[ 23.717] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.740] (II) Module fb: vendor="X.Org Foundation"
[ 23.740] compiled for 1.16.4, module version = 1.0.0
[ 23.740] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.740] (**) FBDEV(0): using shadow framebuffer
[ 23.740] (II) Loading sub module "shadow"
[ 23.740] (II) LoadModule: "shadow"
[ 23.743] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 23.743] (II) Module shadow: vendor="X.Org Foundation"
[ 23.743] compiled for 1.16.4, module version = 1.1.0
[ 23.743] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.743] (II) UnloadModule: "vesa"
[ 23.743] (II) Unloading vesa
[ 23.743] (==) Depth 24 pixmap format is 32 bpp
[ 23.743] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 23.761] (==) FBDEV(0): Backing store enabled
[ 23.761] (==) FBDEV(0): DPMS enabled
[ 23.761] (==) RandR enabled
[ 23.770] (II) SELinux: Disabled on system
[ 23.771] (II) AIGLX: Screen 0 is not DRI2 capable
[ 23.771] (EE) AIGLX: reverting to software rendering
[ 25.504] (II) AIGLX: Loaded and initialized swrast
[ 25.504] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 25.884] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 25.884] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.884] (II) LoadModule: "evdev"
[ 25.884] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.921] (II) Module evdev: vendor="X.Org Foundation"
[ 25.921] compiled for 1.16.0, module version = 2.9.0
[ 25.921] Module class: X.Org XInput Driver
[ 25.921] ABI class: X.Org XInput driver, version 21.0
[ 25.921] (II) Using input driver 'evdev' for 'Power Button'
[ 25.921] (**) Power Button: always reports core events
[ 25.921] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 25.921] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 25.921] (--) evdev: Power Button: Found keys
[ 25.921] (II) evdev: Power Button: Configuring as keyboard
[ 25.921] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event4"
[ 25.921] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 25.921] (**) Option "xkb_rules" "evdev"
[ 25.921] (**) Option "xkb_model" "pc105"
[ 25.921] (**) Option "xkb_layout" "us"
[ 25.922] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[ 25.922] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 25.922] (II) Using input driver 'evdev' for 'Sleep Button'
[ 25.922] (**) Sleep Button: always reports core events
[ 25.922] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[ 25.922] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 25.922] (--) evdev: Sleep Button: Found keys
[ 25.922] (II) evdev: Sleep Button: Configuring as keyboard
[ 25.922] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6/event3"
[ 25.922] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[ 25.923] (**) Option "xkb_rules" "evdev"
[ 25.923] (**) Option "xkb_model" "pc105"
[ 25.923] (**) Option "xkb_layout" "us"
[ 25.923] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event0)
[ 25.923] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 25.924] (II) Using input driver 'evdev' for 'Logitech USB-PS/2 Optical Mouse'
[ 25.924] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[ 25.924] (**) evdev: Logitech USB-PS/2 Optical Mouse: Device: "/dev/input/event0"
[ 25.924] (--) evdev: Logitech USB-PS/2 Optical Mouse: Vendor 0x46d Product 0xc040
[ 25.924] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found 12 mouse buttons
[ 25.924] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
[ 25.924] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found relative axes
[ 25.924] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
[ 25.924] (II) evdev: Logitech USB-PS/2 Optical Mouse: Configuring as mouse
[ 25.924] (II) evdev: Logitech USB-PS/2 Optical Mouse: Adding scrollwheel support
[ 25.924] (**) evdev: Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
[ 25.924] (**) evdev: Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 25.924] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C040.0001/input/input3/event0"
[ 25.924] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 8)
[ 25.924] (II) evdev: Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
[ 25.924] (**) Logitech USB-PS/2 Optical Mouse: (accel) keeping acceleration scheme 1
[ 25.924] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration profile 0
[ 25.924] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[ 25.924] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[ 25.925] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[ 25.925] (II) No input driver specified, ignoring this device.
[ 25.925] (II) This device may have been added with another device file.
[ 25.925] (II) config/udev: Adding input device wired keyboard (/dev/input/event1)
[ 25.925] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.925] (II) Using input driver 'evdev' for ' wired keyboard'
[ 25.926] (**) wired keyboard: always reports core events
[ 25.926] (**) evdev: wired keyboard: Device: "/dev/input/event1"
[ 25.926] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 25.926] (--) evdev: wired keyboard: Found keys
[ 25.926] (II) evdev: wired keyboard: Configuring as keyboard
[ 25.926] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046A:0180.0002/input/input4/event1"
[ 25.926] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 9)
[ 25.926] (**) Option "xkb_rules" "evdev"
[ 25.926] (**) Option "xkb_model" "pc105"
[ 25.926] (**) Option "xkb_layout" "us"
[ 25.927] (II) config/udev: Adding input device wired keyboard (/dev/input/event2)
[ 25.927] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.927] (II) Using input driver 'evdev' for ' wired keyboard'
[ 25.927] (**) wired keyboard: always reports core events
[ 25.927] (**) evdev: wired keyboard: Device: "/dev/input/event2"
[ 25.927] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 25.927] (--) evdev: wired keyboard: Found 1 mouse buttons
[ 25.927] (--) evdev: wired keyboard: Found scroll wheel(s)
[ 25.927] (--) evdev: wired keyboard: Found relative axes
[ 25.927] (II) evdev: wired keyboard: Forcing relative x/y axes to exist.
[ 25.927] (--) evdev: wired keyboard: Found absolute axes
[ 25.927] (II) evdev: wired keyboard: Forcing absolute x/y axes to exist.
[ 25.927] (--) evdev: wired keyboard: Found keys
[ 25.927] (II) evdev: wired keyboard: Configuring as mouse
[ 25.927] (II) evdev: wired keyboard: Configuring as keyboard
[ 25.927] (II) evdev: wired keyboard: Adding scrollwheel support
[ 25.927] (**) evdev: wired keyboard: YAxisMapping: buttons 4 and 5
[ 25.927] (**) evdev: wired keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 25.927] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046A:0180.0003/input/input5/event2"
[ 25.927] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 10)
[ 25.927] (**) Option "xkb_rules" "evdev"
[ 25.927] (**) Option "xkb_model" "pc105"
[ 25.927] (**) Option "xkb_layout" "us"
[ 25.927] (II) evdev: wired keyboard: initialized for relative axes.
[ 25.927] (WW) evdev: wired keyboard: ignoring absolute axes.
[ 25.928] (**) wired keyboard: (accel) keeping acceleration scheme 1
[ 25.928] (**) wired keyboard: (accel) acceleration profile 0
[ 25.928] (**) wired keyboard: (accel) acceleration factor: 2.000
[ 25.928] (**) wired keyboard: (accel) acceleration threshold: 4
[ 25.928] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event7)
[ 25.928] (II) No input driver specified, ignoring this device.
[ 25.928] (II) This device may have been added with another device file.
[ 25.929] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[ 25.929] (II) No input driver specified, ignoring this device.
[ 25.929] (II) This device may have been added with another device file.
[ 25.929] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event9)
[ 25.930] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event10)
[ 25.930] (II) No input driver specified, ignoring this device.
[ 25.930] (II) This device may have been added with another device file.
[ 25.930] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event11)
[ 25.931] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 25.931] (II) No input driver specified, ignoring this device.
[ 25.931] (II) This device may have been added with another device file.
[ 25.931] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event6)
[ 25.931] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 25.931] (II) Using input driver 'evdev' for 'MSI WMI hotkeys'
[ 25.931] (**) MSI WMI hotkeys: always reports core events
[ 25.931] (**) evdev: MSI WMI hotkeys: Device: "/dev/input/event6"
[ 25.932] (--) evdev: MSI WMI hotkeys: Vendor 0 Product 0
[ 25.932] (--) evdev: MSI WMI hotkeys: Found keys
[ 25.932] (II) evdev: MSI WMI hotkeys: Configuring as keyboard
[ 25.932] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event6"
[ 25.932] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 11)
[ 25.932] (**) Option "xkb_rules" "evdev"
[ 25.932] (**) Option "xkb_model" "pc105"
[ 25.932] (**) Option "xkb_layout" "us"
[ 25.938] (EE) FBDEV(0): FBIOBLANK: Invalid argument
Great, we are going to investigate logs, suppose we will answer in a hour or two, please be patient. By the way, you could attach files here, if you follow 'Post reply' link -> Attachment
Well, the preliminary finding is as follows. Both systems uses the same (slow) 'fbdev' graphics driver. The live system, in comparison to the real installation, allocates more memory for the graphics subsystem (for some unknown reason so far), so it's able to select higher resolution.
As a really proper solution, we would need to get Intel graphics driver to work. Now we are going to investigate more, and let you know as some new information is available.
As it's a hardware specific issue, and we are not able to make full testing on the equivalent hardware, the solution could be a bit unstraightforward. As a first attempt, we would recommend you to try to use newer kernel, it should be possibly the most efficient solution. So, follow commands in terminal:
- First, blacklist 'rtkit' package, as it's not compatible with newer kernels and could affect kernel stability, if installed accidentally. Very probably, you will not need this package in the future.
$ sudo apt-get remove rtkit
$ sudo nano /etc/apt/preferences.d/pin50-rtkit
paste following lines into 'pin50-rtkit' file:
Package: rtkit
Pin: release *
Pin-Priority: -1
- Run recent kernel installation:
$ qinst-kernel-bpo
$ sudo reboot
- Check you have booted the new kernel and blacklisted 'rtkit'
$ uname -a
$ apt-cache policy rtkit
Please post result here including the 'Xorg.0.log' file to be checked once more.
Thanks, but no change - still old resolution and not changeable.
$ uname -a
xy@q4os-desktop:~$ uname -a
Linux q4os-desktop 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
The 'rtkit' package was not installed.
[ 3.141]
[ 3.141] X Protocol Version 11, Revision 0
[ 3.141] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 3.141] Current Operating System: Linux q4os-desktop 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64
[ 3.141] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=fa30e211-12b3-4ca8-9601-6b7741a860bf ro quiet loglevel=3 TERM=dumb
[ 3.141] Build Date: 11 February 2015 12:32:02AM
[ 3.141] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 3.141] Current version of pixman: 0.32.6
[ 3.141] Before reporting problems, check http://wiki.x.org
[ 3.141] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.141] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 1 14:33:04 2016
[ 3.143] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.143] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.144] (==) No Layout section. Using the first Screen section.
[ 3.144] (==) No screen section available. Using defaults.
[ 3.144] (**) |-->Screen "Default Screen Section" (0)
[ 3.144] (**) | |-->Monitor "<default monitor>"
[ 3.145] (==) No monitor specified for screen "Default Screen Section".
[ 3.145] (==) Automatically adding devices
[ 3.145] (==) Automatically enabling devices
[ 3.145] (==) Automatically adding GPU devices
[ 3.145] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[ 3.145] Entry deleted from font path.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 3.145] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 3.145] (==) FontPath set to:
built-ins
[ 3.146] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.146] (II) The server relies on udev to provide the list of input devices.
[ 3.146] (II) Loader magic: 0x7ffa31643d80
[ 3.146] (II) Module ABI versions:
[ 3.146] X.Org ANSI C Emulation: 0.4
[ 3.146] X.Org Video Driver: 18.0
[ 3.146] X.Org XInput driver : 21.0
[ 3.146] X.Org Server Extension : 8.0
[ 3.148] (--) PCI:*(0:0:2:0) 8086:22b1:1462:b120 rev 53, Mem @ 0x80000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64
[ 3.149] (II) LoadModule: "glx"
[ 3.149] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.227] (II) Module glx: vendor="X.Org Foundation"
[ 3.227] compiled for 1.16.4, module version = 1.0.0
[ 3.227] ABI class: X.Org Server Extension, version 8.0
[ 3.227] (==) AIGLX enabled
[ 3.227] (==) Matched intel as autoconfigured driver 0
[ 3.227] (==) Matched modesetting as autoconfigured driver 1
[ 3.227] (==) Matched fbdev as autoconfigured driver 2
[ 3.227] (==) Matched vesa as autoconfigured driver 3
[ 3.227] (==) Assigned the driver to the xf86ConfigLayout
[ 3.227] (II) LoadModule: "intel"
[ 3.248] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3.315] (II) Module intel: vendor="X.Org Foundation"
[ 3.315] compiled for 1.15.99.904, module version = 2.21.15
[ 3.315] Module class: X.Org Video Driver
[ 3.315] ABI class: X.Org Video Driver, version 18.0
[ 3.315] (II) LoadModule: "modesetting"
[ 3.316] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.316] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.316] compiled for 1.16.4, module version = 0.9.0
[ 3.316] Module class: X.Org Video Driver
[ 3.316] ABI class: X.Org Video Driver, version 18.0
[ 3.316] (II) LoadModule: "fbdev"
[ 3.316] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 3.316] (II) Module fbdev: vendor="X.Org Foundation"
[ 3.316] compiled for 1.15.99.904, module version = 0.4.4
[ 3.316] (II) LoadModule: "vesa"
[ 3.316] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 3.342] (II) Module vesa: vendor="X.Org Foundation"
[ 3.342] compiled for 1.15.99.904, module version = 2.3.3
[ 3.342] Module class: X.Org Video Driver
[ 3.342] ABI class: X.Org Video Driver, version 18.0
[ 3.342] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 3.343] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.343] (II) FBDEV: driver for framebuffer: fbdev
[ 3.343] (II) VESA: driver for VESA chipsets: vesa
[ 3.343] (++) using VT number 7
[ 3.352] (EE) open /dev/dri/card0: No such file or directory
[ 3.352] (WW) Falling back to old probe method for modesetting
[ 3.352] (II) Loading sub module "fbdevhw"
[ 3.352] (II) LoadModule: "fbdevhw"
[ 3.352] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 3.352] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 3.352] compiled for 1.16.4, module version = 0.0.2
[ 3.352] ABI class: X.Org Video Driver, version 18.0
[ 3.352] (**) FBDEV(1): claimed PCI slot 0@0:2:0
[ 3.352] (II) FBDEV(1): using default device
[ 3.352] (WW) Falling back to old probe method for vesa
[ 3.352] (EE) Screen 0 deleted because of no matching config section.
[ 3.352] (II) UnloadModule: "modesetting"
[ 3.353] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 3.353] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 3.353] (==) FBDEV(0): RGB weight 888
[ 3.353] (==) FBDEV(0): Default visual is TrueColor
[ 3.353] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.353] (II) FBDEV(0): hardware: simple (video memory: 3072kB)
[ 3.353] (II) FBDEV(0): checking modes against framebuffer device...
[ 3.353] (II) FBDEV(0): checking modes against monitor...
[ 3.353] (--) FBDEV(0): Virtual size is 1024x768 (pitch 1024)
[ 3.353] (**) FBDEV(0): Built-in mode "current"
[ 3.353] (++) FBDEV(0): DPI set to (96, 96)
[ 3.353] (II) Loading sub module "fb"
[ 3.353] (II) LoadModule: "fb"
[ 3.353] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3.353] (II) Module fb: vendor="X.Org Foundation"
[ 3.353] compiled for 1.16.4, module version = 1.0.0
[ 3.353] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.353] (**) FBDEV(0): using shadow framebuffer
[ 3.353] (II) Loading sub module "shadow"
[ 3.353] (II) LoadModule: "shadow"
[ 3.353] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 3.353] (II) Module shadow: vendor="X.Org Foundation"
[ 3.353] compiled for 1.16.4, module version = 1.1.0
[ 3.353] (II) UnloadModule: "vesa"
[ 3.353] (II) Unloading vesa
[ 3.353] (==) Depth 24 pixmap format is 32 bpp
[ 3.354] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 3.354] (==) FBDEV(0): Backing store enabled
[ 3.354] (==) FBDEV(0): DPMS enabled
[ 3.354] (==) RandR enabled
[ 3.362] (II) SELinux: Disabled on system
[ 3.363] (II) AIGLX: Screen 0 is not DRI2 capable
[ 3.363] (EE) AIGLX: reverting to software rendering
[ 3.437] (II) AIGLX: Loaded and initialized swrast
[ 3.437] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 3.497] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 3.497] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3.497] (II) LoadModule: "evdev"
[ 3.497] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 3.498] (II) Module evdev: vendor="X.Org Foundation"
[ 3.498] compiled for 1.16.0, module version = 2.9.0
[ 3.498] Module class: X.Org XInput Driver
[ 3.498] ABI class: X.Org XInput driver, version 21.0
[ 3.498] (II) Using input driver 'evdev' for 'Power Button'
[ 3.498] (**) Power Button: always reports core events
[ 3.498] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 3.498] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 3.498] (--) evdev: Power Button: Found keys
[ 3.498] (II) evdev: Power Button: Configuring as keyboard
[ 3.498] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event4"
[ 3.498] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3.498] (**) Option "xkb_rules" "evdev"
[ 3.498] (**) Option "xkb_model" "pc105"
[ 3.498] (**) Option "xkb_layout" "de"
[ 3.543] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[ 3.543] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 3.543] (II) Using input driver 'evdev' for 'Sleep Button'
[ 3.543] (**) Sleep Button: always reports core events
[ 3.543] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[ 3.543] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 3.543] (--) evdev: Sleep Button: Found keys
[ 3.543] (II) evdev: Sleep Button: Configuring as keyboard
[ 3.543] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6/event3"
[ 3.543] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[ 3.543] (**) Option "xkb_rules" "evdev"
[ 3.543] (**) Option "xkb_model" "pc105"
[ 3.543] (**) Option "xkb_layout" "de"
[ 3.544] (II) config/udev: Adding input device wired keyboard (/dev/input/event0)
[ 3.544] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 3.544] (II) Using input driver 'evdev' for ' wired keyboard'
[ 3.544] (**) wired keyboard: always reports core events
[ 3.544] (**) evdev: wired keyboard: Device: "/dev/input/event0"
[ 3.544] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 3.544] (--) evdev: wired keyboard: Found keys
[ 3.544] (II) evdev: wired keyboard: Configuring as keyboard
[ 3.544] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:046A:0180.0001/input/input3/event0"
[ 3.544] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 8)
[ 3.544] (**) Option "xkb_rules" "evdev"
[ 3.545] (**) Option "xkb_model" "pc105"
[ 3.545] (**) Option "xkb_layout" "de"
[ 3.545] (II) config/udev: Adding input device wired keyboard (/dev/input/event1)
[ 3.545] (**) wired keyboard: Applying InputClass "evdev keyboard catchall"
[ 3.545] (II) Using input driver 'evdev' for ' wired keyboard'
[ 3.546] (**) wired keyboard: always reports core events
[ 3.546] (**) evdev: wired keyboard: Device: "/dev/input/event1"
[ 3.546] (--) evdev: wired keyboard: Vendor 0x46a Product 0x180
[ 3.546] (--) evdev: wired keyboard: Found 1 mouse buttons
[ 3.546] (--) evdev: wired keyboard: Found scroll wheel(s)
[ 3.546] (--) evdev: wired keyboard: Found relative axes
[ 3.546] (II) evdev: wired keyboard: Forcing relative x/y axes to exist.
[ 3.546] (--) evdev: wired keyboard: Found absolute axes
[ 3.546] (II) evdev: wired keyboard: Forcing absolute x/y axes to exist.
[ 3.546] (--) evdev: wired keyboard: Found keys
[ 3.546] (II) evdev: wired keyboard: Configuring as mouse
[ 3.546] (II) evdev: wired keyboard: Configuring as keyboard
[ 3.546] (II) evdev: wired keyboard: Adding scrollwheel support
[ 3.546] (**) evdev: wired keyboard: YAxisMapping: buttons 4 and 5
[ 3.546] (**) evdev: wired keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.546] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046A:0180.0002/input/input4/event1"
[ 3.546] (II) XINPUT: Adding extended input device " wired keyboard" (type: KEYBOARD, id 9)
[ 3.546] (**) Option "xkb_rules" "evdev"
[ 3.546] (**) Option "xkb_model" "pc105"
[ 3.546] (**) Option "xkb_layout" "de"
[ 3.546] (II) evdev: wired keyboard: initialized for relative axes.
[ 3.546] (WW) evdev: wired keyboard: ignoring absolute axes.
[ 3.547] (**) wired keyboard: (accel) keeping acceleration scheme 1
[ 3.547] (**) wired keyboard: (accel) acceleration profile 0
[ 3.547] (**) wired keyboard: (accel) acceleration factor: 2.000
[ 3.547] (**) wired keyboard: (accel) acceleration threshold: 4
[ 3.547] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event2)
[ 3.547] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 3.547] (II) Using input driver 'evdev' for 'Logitech USB-PS/2 Optical Mouse'
[ 3.547] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[ 3.547] (**) evdev: Logitech USB-PS/2 Optical Mouse: Device: "/dev/input/event2"
[ 3.547] (--) evdev: Logitech USB-PS/2 Optical Mouse: Vendor 0x46d Product 0xc040
[ 3.547] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found 12 mouse buttons
[ 3.547] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
[ 3.547] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found relative axes
[ 3.547] (--) evdev: Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
[ 3.548] (II) evdev: Logitech USB-PS/2 Optical Mouse: Configuring as mouse
[ 3.548] (II) evdev: Logitech USB-PS/2 Optical Mouse: Adding scrollwheel support
[ 3.548] (**) evdev: Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
[ 3.548] (**) evdev: Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 3.548] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C040.0003/input/input5/event2"
[ 3.548] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 10)
[ 3.548] (II) evdev: Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
[ 3.548] (**) Logitech USB-PS/2 Optical Mouse: (accel) keeping acceleration scheme 1
[ 3.548] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration profile 0
[ 3.548] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[ 3.548] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[ 3.549] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[ 3.549] (II) No input driver specified, ignoring this device.
[ 3.549] (II) This device may have been added with another device file.
[ 3.549] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event7)
[ 3.549] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[ 3.550] (II) This device may have been added with another device file.
[ 3.550] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event9)
[ 3.550] (II) No input driver specified, ignoring this device.
[ 3.550] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event10)
[ 3.551] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event11)
[ 3.551] (II) No input driver specified, ignoring this device.
[ 3.551] (II) This device may have been added with another device file.
[ 3.551] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 3.552] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event6)
[ 3.552] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 3.552] (II) Using input driver 'evdev' for 'MSI WMI hotkeys'
[ 3.552] (**) MSI WMI hotkeys: always reports core events
[ 3.552] (**) evdev: MSI WMI hotkeys: Device: "/dev/input/event6"
[ 3.552] (--) evdev: MSI WMI hotkeys: Vendor 0 Product 0
[ 3.552] (--) evdev: MSI WMI hotkeys: Found keys
[ 3.552] (II) evdev: MSI WMI hotkeys: Configuring as keyboard
[ 3.552] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event6"
[ 3.552] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 11)
[ 3.552] (**) Option "xkb_rules" "evdev"
[ 3.552] (**) Option "xkb_model" "pc105"
[ 3.552] (**) Option "xkb_layout" "de"
[ 3.558] (EE) FBDEV(0): FBIOBLANK: Invalid argument
[ 7.773] (EE) FBDEV(0): FBIOBLANK: Invalid argument
Your UEFI system is still booting the old kernel instead of the newly installed kernel 4.7.
Please try to stop the booting process tapping 'Esc' when you switch on the machine, and then select a non-default 'Q4OS Desktop 1.8, Orion' entry from the grub boot table. As the system loads, run in terminal:
$ uname -v
If the output looks like this:
#1 SMP Debian 4.7.8-1~bpo8+1 (2016-10-19)
you have successfully booted desired new kernel.
EDIT: You may need to enter 'Advanced options ...' entry in the grub boot table.
all grub menu entrys booting the old kernel. i may try it tomorrow with 'super grup 2 disk'
Well, there is probably some mismatch with the UEFI booting. Did the command 'qinst-kernel-bpo' proceed successfully ? You could safely run it again this way:
$ ( qinst-kernel-bpo 2>&1 ) | tee kernel_install.log
look at the output and post the 'kernel_install.log' here to analyze.
...i may try it tomorrow with 'super grup 2 disk'
Yes, it's a good idea.
EDIT: In addition you could post some more info for us to check the grub configuration:
$ ls -l /boot/
$ sudo update-grub
That's it! I don't know why but this time the new kernel is taken and i also did a update grub.
Display resolution is right and changeable!
This script will install latest Linux kernel from backports repository.
Checking internet connection ..
.. link ok.
Updating sw database
Ign http://dl.google.com stable InRelease
Ign http://ftp.debian.org jessie InRelease
Holen: 1 http://security.debian.org jessie/updates InRelease [63,1 kB]
OK http://q4os.org q4os-1-0-cn InRelease
OK http://q4os.org jessie InRelease
Holen: 2 http://ftp.debian.org jessie-updates InRelease [145 kB]
Holen: 3 http://dl.google.com stable Release.gpg [916 B]
Holen: 4 http://dl.google.com stable Release [1.189 B]
Holen: 5 http://ftp.debian.org jessie-backports InRelease [166 kB]
OK http://ftp.debian.org jessie Release.gpg
Holen: 6 http://q4os.org q4os-1-0-cn/main amd64 Packages [4.727 B]
Holen: 7 http://security.debian.org jessie/updates/main amd64 Packages [331 kB]
Holen: 8 http://dl.google.com stable/main amd64 Packages [1.453 B]
Holen: 9 http://q4os.org jessie/main amd64 Packages [240 kB]
Holen: 10 http://ftp.debian.org jessie-updates/main amd64 Packages/DiffIndex [6.916 B]
Holen: 11 http://security.debian.org jessie/updates/contrib amd64 Packages [2.506 B]
Holen: 12 http://ftp.debian.org jessie-updates/contrib amd64 Packages [32 B]
Holen: 13 http://security.debian.org jessie/updates/non-free amd64 Packages [14 B]
Holen: 14 http://ftp.debian.org jessie-updates/non-free amd64 Packages/DiffIndex [736 B]
Holen: 15 http://ftp.debian.org jessie-updates/contrib Translation-en [14 B]
Holen: 16 http://security.debian.org jessie/updates/contrib Translation-en [1.211 B]
Holen: 17 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2.704 B]
Holen: 18 http://security.debian.org jessie/updates/main Translation-en [174 kB]
Holen: 19 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Holen: 20 http://ftp.debian.org jessie-backports/main amd64 Packages/DiffIndex [27,8 kB]
Holen: 21 http://security.debian.org jessie/updates/non-free Translation-en [14 B]
Holen: 22 http://ftp.debian.org jessie-backports/contrib amd64 Packages/DiffIndex [20,3 kB]
Holen: 23 http://ftp.debian.org jessie-backports/non-free amd64 Packages/DiffIndex [15,5 kB]
Holen: 24 http://ftp.debian.org jessie-backports/contrib Translation-en/DiffIndex [6.484 B]
Holen: 25 http://ftp.debian.org jessie-backports/main Translation-en/DiffIndex [27,8 kB]
Holen: 26 http://ftp.debian.org jessie-backports/non-free Translation-en/DiffIndex [12,2 kB]
Holen: 27 http://ftp.debian.org jessie/main amd64 Packages [6.787 kB]
Ign http://dl.google.com stable/main Translation-de_DE
Ign http://dl.google.com stable/main Translation-en
Ign http://q4os.org q4os-1-0-cn/main Translation-de_DE
Ign http://q4os.org q4os-1-0-cn/main Translation-en
Ign http://q4os.org jessie/main Translation-de_DE
Ign http://q4os.org jessie/main Translation-en
Holen: 28 http://ftp.debian.org jessie/contrib amd64 Packages [50,2 kB]
Holen: 29 http://ftp.debian.org jessie/non-free amd64 Packages [83,6 kB]
Holen: 30 http://ftp.debian.org jessie/contrib Translation-en [38,5 kB]
Holen: 31 http://ftp.debian.org jessie/main Translation-de_DE [830 B]
Holen: 32 http://ftp.debian.org jessie/main Translation-de [1.755 kB]
Holen: 33 http://ftp.debian.org jessie/main Translation-en [4.583 kB]
Holen: 34 http://ftp.debian.org jessie/non-free Translation-en [72,3 kB]
Holen: 35 http://ftp.debian.org jessie-backports/main amd64 2016-12-02-0228.29.pdiff [746 B]
Holen: 36 http://ftp.debian.org jessie-backports/main amd64 2016-12-02-0228.29.pdiff [746 B]
Es wurden 14,6 MB in 7 s geholt (1.969 kB/s).
Paketlisten werden gelesen...
Installing amd64 kernel
Abhängigkeitsbaum wird aufgebaut....
Statusinformationen werden eingelesen....
linux-libc-dev ist schon die neueste Version.
linux-libc-dev wurde als manuell installiert festgelegt.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
firmware-linux-free ist schon die neueste Version.
Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
libuuid-perl
Verwenden Sie »apt-get autoremove«, um es zu entfernen.
Die folgenden zusätzlichen Pakete werden installiert:
amd64-microcode firmware-amd-graphics firmware-misc-nonfree gcc-4.9
intel-microcode irqbalance iucode-tool libasan1 libcilkrts5 libgcc-4.9-dev
liblsan0 libnuma1 libubsan0 linux-base linux-compiler-gcc-4.9-x86
linux-headers-4.7.0-0.bpo.1-amd64 linux-headers-4.7.0-0.bpo.1-common
linux-image-4.7.0-0.bpo.1-amd64 linux-kbuild-4.7
Vorgeschlagene Pakete:
gcc-4.9-multilib gcc-4.9-doc gcc-4.9-locales libgcc1-dbg libgomp1-dbg
libitm1-dbg libatomic1-dbg libasan1-dbg liblsan0-dbg libtsan0-dbg
libubsan0-dbg libcilkrts5-dbg libquadmath0-dbg linux-doc-4.7
debian-kernel-handbook
Die folgenden Pakete werden ENTFERNT:
firmware-adi firmware-ralink
Die folgenden NEUEN Pakete werden installiert:
liblsan0 libnuma1 libubsan0 linux-compiler-gcc-4.9-x86
Die folgenden Pakete werden aktualisiert (Upgrade):
firmware-linux firmware-linux-nonfree linux-base linux-headers-amd64
linux-image-amd64
5 aktualisiert, 18 neu installiert, 2 zu entfernen und 75 nicht aktualisiert.
Es müssen 57,0 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 258 MB Plattenplatz zusätzlich benutzt.
Holen: 1 http://ftp.debian.org/debian/ jessie/main libasan1 amd64 4.9.2-10 [195 kB]
Holen: 2 http://ftp.debian.org/debian/ jessie/main libcilkrts5 amd64 4.9.2-10 [40,1 kB]
Holen: 3 http://ftp.debian.org/debian/ jessie/main liblsan0 amd64 4.9.2-10 [92,8 kB]
Holen: 4 http://ftp.debian.org/debian/ jessie/main libnuma1 amd64 2.0.10-1 [32,5 kB]
Holen: 5 http://ftp.debian.org/debian/ jessie/main libubsan0 amd64 4.9.2-10 [82,4 kB]
Holen: 6 http://ftp.debian.org/debian/ jessie-backports/contrib iucode-tool amd64 2.1-1~bpo8+1 [52,7 kB]
Holen: 7 http://ftp.debian.org/debian/ jessie-backports/non-free intel-microcode amd64 3.20161104.1~bpo8+1 [696 kB]
Holen: 8 http://ftp.debian.org/debian/ jessie-backports/non-free firmware-linux-nonfree all 20160824-1~bpo8+1 [13,2 kB]
Holen: 9 http://ftp.debian.org/debian/ jessie-backports/non-free firmware-linux all 20160824-1~bpo8+1 [13,5 kB]
Holen: 10 http://ftp.debian.org/debian/ jessie-backports/non-free firmware-misc-nonfree all 20160824-1~bpo8+1 [2.170 kB]
Holen: 11 http://ftp.debian.org/debian/ jessie-backports/non-free firmware-amd-graphics all 20160824-1~bpo8+1 [1.506 kB]
Holen: 12 http://ftp.debian.org/debian/ jessie/main libgcc-4.9-dev amd64 4.9.2-10 [2.066 kB]
Holen: 13 http://ftp.debian.org/debian/ jessie/main gcc-4.9 amd64 4.9.2-10 [5.352 kB]
Holen: 14 http://ftp.debian.org/debian/ jessie-backports/main linux-base all 4.3~bpo8+1 [19,0 kB]
Holen: 15 http://ftp.debian.org/debian/ jessie-backports/main linux-compiler-gcc-4.9-x86 amd64 4.7.8-1~bpo8+1 [399 kB]
Holen: 16 http://ftp.debian.org/debian/ jessie-backports/main linux-headers-4.7.0-0.bpo.1-common amd64 4.7.8-1~bpo8+1 [5.289 kB]
Holen: 17 http://ftp.debian.org/debian/ jessie-backports/main linux-kbuild-4.7 amd64 4.7.8-1~bpo8+1 [589 kB]
Holen: 18 http://ftp.debian.org/debian/ jessie-backports/main linux-headers-4.7.0-0.bpo.1-amd64 amd64 4.7.8-1~bpo8+1 [502 kB]
Holen: 19 http://ftp.debian.org/debian/ jessie-backports/main linux-headers-amd64 amd64 4.7+75~bpo8+1 [5.726 B]
Holen: 20 http://ftp.debian.org/debian/ jessie-backports/main linux-image-4.7.0-0.bpo.1-amd64 amd64 4.7.8-1~bpo8+1 [37,8 MB]
Holen: 21 http://ftp.debian.org/debian/ jessie-backports/main linux-image-amd64 amd64 4.7+75~bpo8+1 [6.496 B]
Holen: 22 http://ftp.debian.org/debian/ jessie/non-free amd64-microcode amd64 2.20160316.1~deb8u1 [29,6 kB]
Holen: 23 http://ftp.debian.org/debian/ jessie-backports/main irqbalance amd64 1.1.0-2~bpo8+1 [35,1 kB]
Vorkonfiguration der Pakete ...
Es wurden 57,0 MB in 11 s geholt (4.972 kB/s).
(Lese Datenbank ...
(Lese Datenbank ... 5%
(Lese Datenbank ... 10%
(Lese Datenbank ... 15%
(Lese Datenbank ... 20%
(Lese Datenbank ... 25%
(Lese Datenbank ... 30%
(Lese Datenbank ... 35%
(Lese Datenbank ... 40%
(Lese Datenbank ... 45%
(Lese Datenbank ... 50%
(Lese Datenbank ... 55%
(Lese Datenbank ... 60%
(Lese Datenbank ... 65%
(Lese Datenbank ... 70%
(Lese Datenbank ... 75%
(Lese Datenbank ... 80%
(Lese Datenbank ... 85%
(Lese Datenbank ... 90%
(Lese Datenbank ... 95%
(Lese Datenbank ... 100%
(Lese Datenbank ... 78181 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von firmware-adi (0.43) ...
Entfernen von firmware-ralink (0.43) ...
Vormals nicht ausgewähltes Paket libasan1:amd64 wird gewählt.
(Lese Datenbank ...
(Lese Datenbank ... 78158 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../libasan1_4.9.2-10_amd64.deb ...
Entpacken von libasan1:amd64 (4.9.2-10) ...
Vormals nicht ausgewähltes Paket libcilkrts5:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../libcilkrts5_4.9.2-10_amd64.deb ...
Entpacken von libcilkrts5:amd64 (4.9.2-10) ...
Vormals nicht ausgewähltes Paket liblsan0:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../liblsan0_4.9.2-10_amd64.deb ...
Entpacken von liblsan0:amd64 (4.9.2-10) ...
Vormals nicht ausgewähltes Paket libnuma1:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../libnuma1_2.0.10-1_amd64.deb ...
Entpacken von libnuma1:amd64 (2.0.10-1) ...
Vormals nicht ausgewähltes Paket libubsan0:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../libubsan0_4.9.2-10_amd64.deb ...
Entpacken von libubsan0:amd64 (4.9.2-10) ...
Vormals nicht ausgewähltes Paket iucode-tool wird gewählt.
Vorbereitung zum Entpacken von .../iucode-tool_2.1-1~bpo8+1_amd64.deb ...
Entpacken von iucode-tool (2.1-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket intel-microcode wird gewählt.
Vorbereitung zum Entpacken von .../intel-microcode_3.20161104.1~bpo8+1_amd64.deb ...
Entpacken von intel-microcode (3.20161104.1~bpo8+1) ...
Vorbereitung zum Entpacken von .../firmware-linux-nonfree_20160824-1~bpo8+1_all.deb ...
Entpacken von firmware-linux-nonfree (20160824-1~bpo8+1) über (0.43) ...
Vorbereitung zum Entpacken von .../firmware-linux_20160824-1~bpo8+1_all.deb ...
Entpacken von firmware-linux (20160824-1~bpo8+1) über (0.43) ...
Vormals nicht ausgewähltes Paket firmware-misc-nonfree wird gewählt.
Vorbereitung zum Entpacken von .../firmware-misc-nonfree_20160824-1~bpo8+1_all.deb ...
Entpacken von firmware-misc-nonfree (20160824-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket firmware-amd-graphics wird gewählt.
Vorbereitung zum Entpacken von .../firmware-amd-graphics_20160824-1~bpo8+1_all.deb ...
Entpacken von firmware-amd-graphics (20160824-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket libgcc-4.9-dev:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../libgcc-4.9-dev_4.9.2-10_amd64.deb ...
Entpacken von libgcc-4.9-dev:amd64 (4.9.2-10) ...
Vormals nicht ausgewähltes Paket gcc-4.9 wird gewählt.
Vorbereitung zum Entpacken von .../gcc-4.9_4.9.2-10_amd64.deb ...
Entpacken von gcc-4.9 (4.9.2-10) ...
Vorbereitung zum Entpacken von .../linux-base_4.3~bpo8+1_all.deb ...
Entpacken von linux-base (4.3~bpo8+1) über (3.5) ...
Vormals nicht ausgewähltes Paket linux-compiler-gcc-4.9-x86 wird gewählt.
Vorbereitung zum Entpacken von .../linux-compiler-gcc-4.9-x86_4.7.8-1~bpo8+1_amd64.deb ...
Entpacken von linux-compiler-gcc-4.9-x86 (4.7.8-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket linux-headers-4.7.0-0.bpo.1-common wird gewählt.
Vorbereitung zum Entpacken von .../linux-headers-4.7.0-0.bpo.1-common_4.7.8-1~bpo8+1_amd64.deb ...
Entpacken von linux-headers-4.7.0-0.bpo.1-common (4.7.8-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket linux-kbuild-4.7 wird gewählt.
Vorbereitung zum Entpacken von .../linux-kbuild-4.7_4.7.8-1~bpo8+1_amd64.deb ...
Entpacken von linux-kbuild-4.7 (4.7.8-1~bpo8+1) ...
Vormals nicht ausgewähltes Paket linux-headers-4.7.0-0.bpo.1-amd64 wird gewählt.
Vorbereitung zum Entpacken von .../linux-headers-4.7.0-0.bpo.1-amd64_4.7.8-1~bpo8+1_amd64.deb ...
Entpacken von linux-headers-4.7.0-0.bpo.1-amd64 (4.7.8-1~bpo8+1) ...
Vorbereitung zum Entpacken von .../linux-headers-amd64_4.7+75~bpo8+1_amd64.deb ...
Entpacken von linux-headers-amd64 (4.7+75~bpo8+1) über (3.16+63) ...
Vormals nicht ausgewähltes Paket linux-image-4.7.0-0.bpo.1-amd64 wird gewählt.
Vorbereitung zum Entpacken von .../linux-image-4.7.0-0.bpo.1-amd64_4.7.8-1~bpo8+1_amd64.deb ...
Entpacken von linux-image-4.7.0-0.bpo.1-amd64 (4.7.8-1~bpo8+1) ...
Vorbereitung zum Entpacken von .../linux-image-amd64_4.7+75~bpo8+1_amd64.deb ...
Entpacken von linux-image-amd64 (4.7+75~bpo8+1) über (3.16+63) ...
Vormals nicht ausgewähltes Paket amd64-microcode wird gewählt.
Vorbereitung zum Entpacken von .../amd64-microcode_2.20160316.1~deb8u1_amd64.deb ...
Entpacken von amd64-microcode (2.20160316.1~deb8u1) ...
Vormals nicht ausgewähltes Paket irqbalance wird gewählt.
Vorbereitung zum Entpacken von .../irqbalance_1.1.0-2~bpo8+1_amd64.deb ...
Entpacken von irqbalance (1.1.0-2~bpo8+1) ...
Trigger für man-db (2.7.0.2-5) werden verarbeitet ...
Trigger für systemd (215-17+deb8u5) werden verarbeitet ...
libasan1:amd64 (4.9.2-10) wird eingerichtet ...
libcilkrts5:amd64 (4.9.2-10) wird eingerichtet ...
liblsan0:amd64 (4.9.2-10) wird eingerichtet ...
libnuma1:amd64 (2.0.10-1) wird eingerichtet ...
libubsan0:amd64 (4.9.2-10) wird eingerichtet ...
iucode-tool (2.1-1~bpo8+1) wird eingerichtet ...
intel-microcode (3.20161104.1~bpo8+1) wird eingerichtet ...
update-initramfs: deferring update (trigger activated)
intel-microcode: microcode will be updated at next boot
firmware-misc-nonfree (20160824-1~bpo8+1) wird eingerichtet ...
firmware-amd-graphics (20160824-1~bpo8+1) wird eingerichtet ...
firmware-linux-nonfree (20160824-1~bpo8+1) wird eingerichtet ...
firmware-linux (20160824-1~bpo8+1) wird eingerichtet ...
libgcc-4.9-dev:amd64 (4.9.2-10) wird eingerichtet ...
gcc-4.9 (4.9.2-10) wird eingerichtet ...
linux-base (4.3~bpo8+1) wird eingerichtet ...
linux-compiler-gcc-4.9-x86 (4.7.8-1~bpo8+1) wird eingerichtet ...
linux-headers-4.7.0-0.bpo.1-common (4.7.8-1~bpo8+1) wird eingerichtet ...
linux-kbuild-4.7 (4.7.8-1~bpo8+1) wird eingerichtet ...
linux-headers-4.7.0-0.bpo.1-amd64 (4.7.8-1~bpo8+1) wird eingerichtet ...
linux-headers-amd64 (4.7+75~bpo8+1) wird eingerichtet ...
linux-image-4.7.0-0.bpo.1-amd64 (4.7.8-1~bpo8+1) wird eingerichtet ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-3.16.0-4-amd64
I: /initrd.img.old is now a symlink to boot/initrd.img-3.16.0-4-amd64
I: /vmlinuz is now a symlink to boot/vmlinuz-4.7.0-0.bpo.1-amd64
I: /initrd.img is now a symlink to boot/initrd.img-4.7.0-0.bpo.1-amd64
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-4.7.0-0.bpo.1-amd64
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r8169
/etc/kernel/postinst.d/zz-update-grub:
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-4.7.0-0.bpo.1-amd64
Found initrd image: /boot/initrd.img-4.7.0-0.bpo.1-amd64
Found linux image: /boot/vmlinuz-3.16.0-4-amd64
Found initrd image: /boot/initrd.img-3.16.0-4-amd64
No volume groups found
Adding boot menu entry for EFI firmware configuration
done
linux-image-amd64 (4.7+75~bpo8+1) wird eingerichtet ...
amd64-microcode (2.20160316.1~deb8u1) wird eingerichtet ...
amd64-microcode: microcode will be updated at next boot
irqbalance (1.1.0-2~bpo8+1) wird eingerichtet ...
Trigger für libc-bin (2.19-18+deb8u6) werden verarbeitet ...
Trigger für initramfs-tools (0.120+deb8u2) werden verarbeitet ...
Installation completed, please reboot your system.
xy@q4os-desktop:~$ ls -l /boot
insgesamt 47141
-rw-r--r-- 1 root root 157721 Okt 19 08:45 config-3.16.0-4-amd64
-rw-r--r-- 1 root root 181987 Okt 20 07:10 config-4.7.0-0.bpo.1-amd64
drwx------ 3 root root 512 Jan 1 1970 efi
drwxr-xr-x 5 root root 4096 Dez 2 10:55 grub
-rw-r--r-- 1 root root 16818040 Dez 1 10:40 initrd.img-3.16.0-4-amd64
-rw-r--r-- 1 root root 18219478 Dez 2 10:55 initrd.img-4.7.0-0.bpo.1-amd64
-rw-r--r-- 1 root root 2679264 Okt 19 08:45 System.map-3.16.0-4-amd64
-rw-r--r-- 1 root root 3125556 Okt 20 07:10 System.map-4.7.0-0.bpo.1-amd64
-rw-r--r-- 1 root root 3126448 Okt 19 08:41 vmlinuz-3.16.0-4-amd64
-rw-r--r-- 1 root root 3937568 Okt 20 07:09 vmlinuz-4.7.0-0.bpo.1-amd64
xy@q4os-desktop:~$ sudo update-grub
done
Great, now you should have accelerated and proper Intel graphics driver working.
Please don't forget to blacklist 'rtkit' package as described above. We are going to update the 'qinst-kernel-bpo' script to include 'rtkit' blacklisting to be performed automatically. It will be available within the next update of the 'q4os-base' package, doing 'update && upgrade' will bring it for Q4OS users.
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for module r8169 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r8169
You might need to install firmware-realtek too to get rid of these error messages, although I had these on one of my systems and it did work ok without the firmware, but I installed it anyway to remove the errors.
i'm not sure if rtkit is really blacklistet. but i did as you discribed.
xy@q4os-desktop:~$ apt-cache policy rtkit
rtkit:
Installiert: (keine)
Installationskandidat: (keine)
Paket-Pinning: 0.11-2
Versionstabelle:
0.11-2 -1
500 http://ftp.debian.org/debian/ jessie/main amd64 Packages
xy@q4os-desktop:~$
@Dai_trying
$ sudo apt-get update && apt-get install firmware-realtek
returns a message that already newest driver is installed.
My system works also fine without these driver.
xy@q4os-desktop:~$ apt-cache policy rtkit rtkit: Installiert: (keine) Installationskandidat: (keine) Paket-Pinning: 0.11-2 Versionstabelle: 0.11-2 -1 500 http://ftp.debian.org/debian/ jessie/main amd64 Packages xy@q4os-desktop:~$
Yes, that's all right. You can test it this way:
$ sudo apt-get install rtkit
Apt should refuse 'rtkit' installation.
