#1 2016-11-05 17:44
nomadxp1
Sound server fatal error: cpu overload, aborting
When booting Q4os I get this error : Sound server fatal error:
this is only on Q4os
Which I don't think has any affect on the system..I have other sound problems but they are also on my other operating systems...eg loud noise on you tube videos etc..
#2 2016-11-05 18:08
Re: Sound server fatal error: cpu overload, aborting
Please specify your hardware, at least CPU and RAM size. Run following terminal commands and put output here to analyze:
$ dpkg -s pulseaudio | grep -i status
$ dpkg -s rtkit | grep -i status
$ uname -a
#3 2016-11-05 21:26
If you could post the output of inxi -F it would describe your system fully, you may need to install inxi first.
#4 2016-11-09 22:39
nomadxp1
Here is what inxi says:
System:    Host: raspberrypi Kernel: 4.4.26-v7+ armv7l (32 bit) Desktop: KDE 3
           Distro: Raspbian GNU/Linux 8
Machine:   No /sys/class/dmi, using dmidecode: you must be root to run dmidecode
CPU:       Quad core ARMv7 rev 4 (v7l) (-MCP-) (ARM)
           Clock Speeds: 1: 1000 MHz 2: 1000 MHz 3: 1000 MHz 4: 1000 MHz
Graphics:  Card: Failed to Detect Video Card!
           Display Server: X.Org 1.17.2 driver: N/A
and as sudo:
ystem:    Host: raspberrypi Kernel: 4.4.26-v7+ armv7l (32 bit) Desktop: N/A
Machine:   No /sys/class/dmi, using dmidecode: no machine data available
           Display Server: X.org 1.17.2 driver: N/A
           tty size: 80x25 Advanced Data: N/A for root
Audio:     Card bcm2835 ALSA driver: bcm2835 Sound: ALSA v: k4.4.26-v7+
Network:   Card: Standard Microsystems SMSC9512/9514 Fast Ethernet Adapter
           IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    HDD Total Size: 240.1GB (49.4% used)
           ID-1: USB /dev/sda model: 240GB size: 240.1GB
Partition: ID-1: / size: 30G used: 20G (72%) fs: ext4 dev: /dev/root
           ID-2: /boot size: 63M used: 21M (33%) fs: vfat dev: /dev/mmcblk0p1
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 199 Uptime: 4 days Memory: 485.4/925.5MB
           Client: Shell (sudo) inxi: 2.1.28
           Resolution: 1366x768@0.00hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.7, 128 bits)
           GLX Version: 3.0 Mesa 11.1.0
Info:      Processes: 201 Uptime: 4 days Memory: 474.9/925.5MB
           Client: Shell (bash) inxi: 2.1.28
hope this helps..thanks
#5 2016-11-09 22:47
I don't think I will be able to help on ths as it is Pi and I do not yet have a box for testing...
Secondly could you surround your terminal output in the post with code blocks
[code]your text here[/code]
as it will make it more readable (or maybe it's just me smile )
And also if you could post the output from the commands the dev team requested too (they are more likely to be able to help with this)
#6 2016-11-09 23:03
nomadxp1
ok..installed pulseaudio problem solved..Thanks again folks..
#7 2016-11-09 23:09
We would recommend you to check 'rtkit' package. It could be the source of audio system issues, please see this topic http://www.q4os.org/forum/viewtopic.php?pid=5246#p5246
