#1 2016-10-22 14:31
SCORPION [2.2.1] binutils being held back
I have re-installed Scorpion and have done update and dist-upgrade, I have 1 package that is reporting as upgradeable (binutils 2.26.1-1 -> 2.27-8)
apt-get dist-upgrade tells me
The following packages have been kept back:
  binutils
I was about to install desktop profile and it failed with the following debug output
linux-headers-amd64 : Depends: linux-headers-4.7.0-1-amd64 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Error: Simulation not successful.
If I try to force upgrade binutils I get the warning
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  q4os-desktop q4os-base (due to q4os-desktop)
  tde-style-q4oststyle01-trinity (due to q4os-desktop)
  tde-style-q4oststyle02-trinity (due to q4os-desktop)
  tdm-trinity (due to q4os-desktop) tdebase-trinity (due to q4os-desktop)
  tdescreensaver-trinity (due to q4os-desktop)
  kmix-trinity (due to q4os-desktop) tdesudo-trinity (due to q4os-desktop)
  kuser-trinity (due to q4os-desktop) krusader-trinity (due to q4os-desktop)
1 upgraded, 0 newly installed, 42 to remove and 0 not upgraded.
I have traced backwards and it appears binutils >= 2.27 is required for gcc-5, which is what causes this error. Is there a problem with binutils in scorpion?
#2 2016-10-22 15:38
Re: SCORPION [2.2.1] binutils being held back
Yes, binutils is held back to satisfy strong 'libr0' dependency from TDE. We will try to update libr0 to free binutils upgrade as soon as possible.
#3 2016-10-22 15:40
Ok, Thanks. smile
#4 2016-10-22 15:44
You could try to install attached libr0 package and see, if it works. Untested, could break the system...
$ sudo dpkg -i --force-all libr0_0.6.0-3debian9.0.0+4-b_amd64.deb
$ sudo dpkg -i --force-all libr-dev_0.6.0-3debian9.0.0+4-b_amd64.deb
$ sudo apt-get install -f
Edit1: updated install instructions
Edit2: added libr-dev package
Edit3: added i386 packages
Edit4: attachments removed, as issue fixed
#5 2016-10-22 18:06
That seems to be working ok, but I cannot install firefox, although firefox-esr is available so I can use that for now. Thanks for the fix smile
#6 2016-10-23 17:38
Now officially fixed, update&&upgrade should solve the issue.
#7 2016-10-23 17:41
Great work team, thanks again smile
