I have re-installed Scorpion and have done update and dist-upgrade, I have 1 package that is reporting as upgradeable (binutils 2.26.1-1 -> 2.27-8)
apt-get dist-upgrade tells me
The following packages have been kept back:
binutilsI was about to install desktop profile and it failed with the following debug output
linux-headers-amd64 : Depends: linux-headers-4.7.0-1-amd64 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Error: Simulation not successful.If I try to force upgrade binutils I get the warning
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
q4os-desktop q4os-base (due to q4os-desktop)
tde-style-q4oststyle01-trinity (due to q4os-desktop)
tde-style-q4oststyle02-trinity (due to q4os-desktop)
tdm-trinity (due to q4os-desktop) tdebase-trinity (due to q4os-desktop)
tdescreensaver-trinity (due to q4os-desktop)
kmix-trinity (due to q4os-desktop) tdesudo-trinity (due to q4os-desktop)
kuser-trinity (due to q4os-desktop) krusader-trinity (due to q4os-desktop)
1 upgraded, 0 newly installed, 42 to remove and 0 not upgraded.I have traced backwards and it appears binutils >= 2.27 is required for gcc-5, which is what causes this error. Is there a problem with binutils in scorpion?
Yes, binutils is held back to satisfy strong 'libr0' dependency from TDE. We will try to update libr0 to free binutils upgrade as soon as possible.
Ok, Thanks.
You could try to install attached libr0 package and see, if it works. Untested, could break the system...
$ sudo dpkg -i --force-all libr0_0.6.0-3debian9.0.0+4-b_amd64.deb
$ sudo dpkg -i --force-all libr-dev_0.6.0-3debian9.0.0+4-b_amd64.deb
$ sudo apt-get install -f
Edit1: updated install instructions
Edit2: added libr-dev package
Edit3: added i386 packages
Edit4: attachments removed, as issue fixed
That seems to be working ok, but I cannot install firefox, although firefox-esr is available so I can use that for now. Thanks for the fix
Now officially fixed, update&&upgrade should solve the issue.
Great work team, thanks again
