#1 2016-05-14 17:01
Add deb-multimedia repository
Do I have to install the proprietary codecs to get deb-multimedia repository available? or can I just add the repo to /etc/apt/sources.list?
#2 2016-05-14 17:05
Re: Add deb-multimedia repository
You can just add the repo - I've done it that way in one install, however the script provided by Q4OS also adds the relevant entry to unattended upgrades - which is nice as that is my preferred update process.
The instructions on the deb multimedia site also provide the keyring info as well.
#3 2016-05-14 17:51
Thanks bin, I usually add the repo to sources.list and then add the keyring manually (On Debian) but wondered if there was a preferred way to do it in Q4OS using either the scripts in /etc/apt/sources.list.d/ or whether there was another script to add the repos without installing the proprietary codecs.
#4 2016-05-14 19:01
This command will get the job:
$ sudo qrepoadd --gui
See http://www.q4os.org/dqa007.html#extrepo
#5 2016-05-14 19:42
Aaaffgghh Another rtfm moment sorry guys and thanks smile
