#1 2016-05-03 22:40
ThisGuy1996
Malformed URL trash
Can't access my trash can
#2 2016-05-04 00:55
Re: Malformed URL trash
Do you mean it does nothing when you double click it? or you don't get context menu when you right click it? or something else?
#3 2016-05-04 03:12
ThisGuy1996
I get an error saying: Error KIOExec Malformed URL trash:/. I tried deleting the shortcut and placing it back, but samething.
#4 2016-05-04 03:37
ThisGuy1996
I tried to go to settings, TDE components, Default Applications, then I got en error saying "TEDInit could not launch 'Konqueror'.:
Could not find 'Konqureror' executable.
#5 2016-05-04 04:24
ThisGuy1996
Please help I don't want to have to reinstall Q4OS.
#6 2016-05-04 10:00
You could try this (from your home directory) :-
cd .local/share/Trash/files/
rm *
cd ../info
rm *
cd ~
that should clear anything that is pending in the trash and should all be ok from there.
#7 2016-05-04 15:25
ThisGuy1996
Okay thank you that worked. But now other shortcuts are not working. When I click on My Computer shortcut, I get an error saying:  Error KIOExec Malformed URL system:/
In the I right click on the files associations in control panel, but says Konqueror executable is not found.
#8 2016-05-04 16:00
Hmm.. I haven't had this error myself but I would try re-installing konqueror and see if that helps
#9 2016-05-04 16:13
ThisGuy1996
Tried that.....nothing. I did find this though:http://ubuntuforums.org/showthread.php?t=996971
In the file associations link, Konqueror executable is missing. I might need to find the location of the Konqueror executable. I can't find it though.
#10 2016-05-04 16:51
/opt/trinity/bin/konqueror
#11 2016-05-04 16:59
ThisGuy1996
Thank you. If I choose to open through Konqueror it says: TEDInit could not launch 'Konqueror'.:
This is getting annoying. I might have to reinstall Q4OS sad
#12 2016-05-04 17:24
If you do I suggest that you do the install, add any apps, do the kcmodules unblock,  then install system back. Have a look at the recent thread on Clonezilla. Before you make any more changes create a restore point so that you can recover to good known point  in time in a matter of minutes.
#13 2016-05-04 17:52
I'd say that's pretty good advice if you will be changing your system a lot, a couple of alternatives that I often do would be run anything you are testing either in a virtual-box or in a separate installation (I have three q40s installs on this pc main/lamp/test) and what I do with virtual-box is set-up a single installation with all updates and then export to ova so it can be re-installed in a couple of minutes when I need to.
One benefit of having multiple installations is being able to look on another partition/virtual-box to see where program/log files should be etc.
#14 2016-05-04 18:12
ThisGuy1996
Thank You both for your help. I had backed up before I did a reinstall, and fifteen minutes later It like it never happened. I'll take a look at clonezilla. I should use virtualbox next time I want to change something.
#15 2016-05-06 18:57
Clonezilla might be a bit difficult, try Systemback first.
https://sourceforge.net/projects/systemback/
http://www.q4os.org/forum/viewtopic.php?pid=3793#p3793
