#1 2016-05-01 12:10
Give user an image
I am trying to use an image for a user in Control Centre -> Security & Privacy -> Password & User Account, but when I click the blank image it gives me a warning dialog saying "Your administrator has disallowed changing your image.", is there a setting somewhere to allow this?
#2 2016-05-01 17:09
Re: Give user an image
Strange, I can freely change user image in the way you have written.
http://files.inbox.lv/ticket/15faf1a1d9 … Avatar.mkv
Please, write back, can you freely download and watch video file, I have provided.
#3 2016-05-01 17:26
That is strange, I wonder what I have changed to stop that from being allowed??? I will have to check on another installation and see if that works, Thanks for letting me know smile
#4 2016-05-01 23:45
I have obviously done something on this installation to prevent users from adding images as I tried other installations and they work fine. Thank you Rademes.
So the question now would be how could I prevent users from changing their logo as described in post #1, hopefully I can find a way to revert whatever I have done as I don't really want to wipe this installation down because it's my main "work" installation. sad
note to myself Always use other installations for testing stuff!!
#5 2016-05-02 01:57
DavidB
I get the same message as you Dai.  I can't specify an image for my Login ID either.  I can't think of anything that I've done to prevent this.
Current setup:  Acer Aspire One D257 / Q4OS 6.10
#6 2016-05-02 06:37
First run in terminal:
$ sudo kcmodules --unlock
Go to Control Panel -> System Administration -> Login Manager -> User -> User Image Source -> Admin
#7 2016-05-02 10:17
Thanks Q4osteam, I changed the setting to user, rebooted and still cannot change the user image on some of my systems, I have tested 4 64 bit installations 2 work 2 don't, I checked 3 32bit installations and they all work, I don't remember changing anything regarding users, but that's not to say I haven't.
@DavidB
    Thanks for letting me know I'm not the only one smile It is a bit strange but hopefully we can find a solution somewhere, I did find a temporary solution by setting the User Image source to User and then I can manually replace ~/.face.icon with an appropriate png image. Not good to have to manually do this but it is a short term fix for anyone wanting an image there.
#8 2016-05-02 10:22
I found it! set user image sources to User, Admin and it should work cool
#9 2016-05-03 03:53
DavidB
Hey, look at that!  It worked!  Good going, Dai.
