Hello! After upgrading Q4OS from Gemini to Andromeda I can no longer mount my external hard drive via USB; it shows up in Dolphin but is not possible to mount. USB memory sticks mount and work as expected. The hard drive works well in Debian and Windows.
Are you able to reproduce the issue, within the live Q4OS 6 Andromeda media?
When I mounted the drive in Windows this morning I got a notice from the operating system that there is a problem with the drive. Windows adviced me to let it scan and repair the drive. I did so and now it can be mounted and used also in Q4OS Andromeda.
Thanks for letting us know, +1
Please also read about major upgrades https://www.q4os.org/forum/viewtopic.php?id=4323
Now again the external hard drive cannot be mounted in Q4OS Andromeda. This time Windows finds no faults with it and mounts it as expected. Dolphin in Q4OS, however, says the following: "Error mounting /dev/sbd1 at /media/magnus/1F223A0D71EFD5D7: wrong fs type, bad option, bad superblock on /dev/sdb1, missing codepage or helper program, or other error". What can be done to resolve this issue?
Hello Magnus,
The ID in your error (1F223A0D71EFD5D7) is an NTFS volume serial number, so this is an NTFS mounting problem. Most likely Windows left the volume flagged as "dirty" or partly hibernated (Fast Startup), even though Windows itself opens it without complaint. That would also explain why the first repair helped only for a while.
I run into this same problem sometimes when creating a Rescuezilla image of my dual boot system (W10 + Q4OS - Perseus (Forky).
Andromeda is based on a newer Debian, where desktop mounting normally uses the in-kernel ntfs3 driver rather than the older ntfs-3g.
ntfs3 is much stricter and refuses a volume with the dirty flag set, whereas Gemini was more forgiving.
I've laid out a multiple step protocol for you to follow.
1. First step
Plug in the drive, try to mount it in Dolphin, then run in a terminal:
sudo dmesg | tail -30Look for lines mentioning ntfs3, "volume is dirty", "hibernated" or "unclean".
2. Disable Fast Startup in Windows
Control Panel → Power Options → "Choose what the power buttons do" → "Change settings that are currently unavailable" → untick "Turn on fast startup".
Also use "Safely Remove Hardware" before unplugging the drive.
3. Clear the dirty flag
In Windows, open Command Prompt as administrator and run (replace E: with your drive letter):
chkdsk E: /fOr in Q4OS, with the drive unmounted:
sudo apt install ntfs-3g
sudo ntfsfix /dev/sdb1Your error message says "sbd1", but it should be "sdb1". Confirm the device name with:
lsblk -f4. Mount with ntfs-3g manually
sudo mkdir -p /mnt/usbdisk
sudo mount -t ntfs-3g /dev/sdb1 /mnt/usbdiskIf this works, the problem is simply ntfs3 being strict.
If ntfs-3g complains about hibernation, the drive needs a clean shutdown from Windows (see step 2).
5. Optional: make Dolphin use ntfs-3g by default
Create the file /etc/udisks2/mount_options.conf with this content:
[defaults]
ntfs_drivers=ntfs3g,ntfs3Then unplug and replug the drive.
If lsblk -f does not show ntfs for that partition, or dmesg shows I/O or hardware errors, please post that output here.
The cause could then be the drive or the USB cable rather than the filesystem.
Hope this helps.
Cheers
Q
Hello, Qwertius, and many thanks for your detailed help! I have done your first step and could read in the terminal, the last four lines:
[ 113.375361] ntfs3(sdb1): It is recommened to use chkdsk.
[ 119.306081] ntfs3(sdb1): volume is dirty and "force" flag is not set!
[ 1037.960255] ntfs3(sdb1): It is recommened to use chkdsk.
[ 1038.057778] ntfs3(sdb1): volume is dirty and "force" flag is not set!
Can I use chkdsk in the terminal in Q4OS?
