#51 2026-04-26 00:18
electricroo
Re: S4 Snapshot - create live media and the full image of your system
This old PC uses Legacy Bios!
#52 2026-04-26 10:41
@electricroo
We can confirm issue when creating a snapshot from within Q4OS for Windows setup. We are adding this one to our bug list. Thanks for the report.
#53 2026-07-22 17:56
@electricroo
The issue you reported https://www.q4os.org/forum/viewtopic.ph … 484#p34484 should be fixed withing the new Q4OS winsetup 6.8 release. Could you please confirm ? You need to download new q4os-winsetup-6.8-r1.zip from https://www.q4os.org/downloads1.html
#54 2026-07-24 21:31
jozeywhales
Hello,
I installed Q4OS Plasma a couple days ago to try it out and pleased with it so far!
I've been mostly using Arch flavored OS's the last 2-3 years.
I found MX Arch last week and installed it then and it is working very nicely also. I tried the Snapshot feature on it and really like it!.
I stumbled onto this thread after doing a search to see if MX Snapshot would work on Q4OS.
After getting just about all the software/programs I use installed on Q4OS I installed S4 Snapshot today and ran it. Took 23 minutes to produce my ISO which was 49GB in size.
My intention in doing so is I'm looking for a stable Plasma to put on my laptop that doesn't have to be updated as often as Arch OS's.
I copied the ISO to my Ventoy thumb drive and rebooted and selected the S4 Snapshot ISO.
It booted within a minute or so and there was my whole system, all my programs, all my customization's, etc., etc. Very cool!!
I started the installer with no issue and it was ready to install my system to wherever I wanted it.
I booted back into Q4OS on my desktop drive and used the S4 Live USB Maker to install the ISO on a 64GB thumb drive. This took about 90 minutes to complete but probably was a combination of the large size of the ISO and the thumb drive speed?
It completed successfully so I rebooted into the that thumb drive and only after about a minute or so I was back in my original installation again, working perfectly! Tried the installer again and it fired up no issues.
I believe I found my new OS for my laptop smile and I'm going to continue running Q4OS on my main machine and see how it goes.
I really liked the choice of being able to install a minimum system (MX Linux has a lot of extra stuff I don't really need).
A very enjoyable journey so far into the Q4OS world! smile
#55 2026-08-02 12:34
@electricroo
It would be helpful, if you could confirm S4-snapshot issue https://www.q4os.org/forum/viewtopic.ph … 484#p34484 is now resolved on your side.
#56 2026-08-05 14:07
niteflyer
Continuing my post from 2025-12-22 15:59 - Thank you for fixing the issue with S4-Snapshot/MX-Snapshot for usage in live sessions without persistence!
Good work: I am able to install these apps in a live session and do a snapshot with them. The ISOs boot, but somehow the system got unasable with the snapshots.
More than once in a minute mouse movement stops for about 5 seconds, same with keyboard input: key presses are not accepted while the text cursor still blinks!
I did my tests with a Q4OS 6.8-TDE live session, no other apps installed, only configured network to get Wifi working and stop notifications, disabled energy saving and screensaver.
After installing mx-tools from your experimental apps, I did a logout/login and made a snapshot with MX-Snapshot and booted the ISO.
I have repeated the same with a vanilla ISO and the installation of S4-Snapshot from your experimental apps: same result with the resulting snapshot.
Two minor inconveniences with Q4OS 6.8-TDE, I have already noticed in prior versions:
1) After clicking "Logout" in the startmenu or the desktop's contextmenu, the logout panel shows up immediately, but after clicking one of the buttons, it takes 20-30s until the action is accepted.
2) As I am still booting ISOs with Ventoy 1.1.0.0, it would be fine when the boot partition would show up in Konqueror's "Storage Media" to be able to copy a new snapshot to Ventoy's ISO-folder. Currently I am using MX-Linux 23.6 XFCE live sessions and with this distro there is no such issue and MX-Snapshot works like a charm...
#57 2026-08-05 14:52
Thank you for testing and reporting back.
The periodic 5-second freezes are definitely not expected. We have not been able to reproduce this behavior so far, so we'll investigate whether it is related to running a snapshot created from a live session or to another component included in the generated ISO.
Could you please provide a few more details?
Does the issue also occur after installing the snapshot to a hard disk, or only when booting the ISO as a live system?
Are you booting the snapshot directly with Ventoy, or does the same happen when the ISO is written to a USB flash drive using a standard imaging tool?
Could you post the output of:
$ journalctl -b
$ dmesg
from the affected snapshot, and mention your hardware specifications?
Regarding the other points:
The delayed response of the logout dialog is a separate issue. We'll investigate it independently. Thank you for the suggestion regarding Ventoy integration. We appreciate your testing. Reports like yours help us improve S4 Snapshot.
#58 2026-08-13 05:21
Bearbutt1
Q4OS is the BEST....... BUT
I am running q4os 6.8 tde because old things are better with the latest guts Debian 13 Trixie! Whoop!
I am trying to build a live boot via Ventoy and must build the ISO image to work with Ventoy. The current format is not due able. So if there are any super nerds out here that can " sudo xorriso -as mkisofs " the proper CALL syntax lets talk. It must be deconstructed first then built. A master of ISO9660 and ELTORITO with a touch of DEBIAN. I believe I am about half way at the moment. Scouring man xorriso and mkisofs at the moment along with the expressed interest in joliet and efi bootable ISO . Think I'll kill this usb stick with all the transfers I have made so far smile
Sure I could S4 Snapshot  with a breeze to an external HHD, but where is the fun or learning in that. plus then it's not a LIVE volume is it?
Again I need ONE ISO burn of the q4so-6.8-x64-tdw.r1.iso , syntax call help.
No - you cant dd it to ventoy, it overwrites
No -  you cant burn a iso image to HD and drag and drop to many efi and boot files
No - I can't just give up - Its fun to learn, crash and burn!
Soon as I figure this ISO burn, I will try to chroot this q4os.iso on a Android. Via termux and termux X-11
Live long and prosper NERDS cool
Update : 08/23/26  I am still working on this. I had a snag, well because of all my other projects. Mostly the snag is getting all three EL TORITO ISO9660 and the culprit JOLIET to meld. I have came across a new way to try but I must study to learn the operation because it is not well documented other than by itself. Worse case I'll drop the JOLIET jive because I simply will not use windows or microsoft. But considering I have received ZERO help from the community, this is my project alone. I've come close but it simply would not boot after the Ventoy boot and load happened.
I also busy with computer education, basics, coding, computer sciences, now picking up a fresh PAM course plus I am composing my first XDA forum post on a Android build I've done. Soon to drop that.
Will keep this posted with updates until I crack the code and then do my own right up on the how to in a fresh post.
ANY HELP?
