#1 2026-08-05 09:08
green-moomin
Default keyboard layout keeps reverting to GB
A similar question has already been asked in 2020 (forum/viewtopic.php?id=4341) and I'm looking for further advice.
I am using a USB keyboard with my laptop. The USB keyboard is US layout and my laptop is GB layout. I use the USB keyboard 90% of the time, so in Control Center, I set the Keyboard Layout to be US. I also modify the /etc/default/keyboard file (like in the above linked post) to:
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="us"
XKBVARIANT=""
BACKSPACE="guess"
However, every 12 hours or whenever I reboot/shutdown, the layout reverts to GB. The login screen also doesn't let me choose a keyboard layout. Is there a way to prevent this behavior?
Output of "uname -a"
Linux mycomputer 6.12.96+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.96-1 (2026-07-20) x86_64 GNU/Linux
#2 2026-08-05 09:26
Re: Default keyboard layout keeps reverting to GB
Welcome to the forum smile
What desktop environment are you using, Plasma/Trinity/other ?
#3 2026-08-05 10:03
green-moomin
Hello, I am using Trinity.
inxi output gives me:
System:
  Host: mycomputer Kernel: 6.12.96+deb13-amd64 arch: x86_64 bits: 64
  Desktop: TDE (Trinity) v: R14.1.5 Distro: Q4OS 6.8-deb13u1
#4 2026-08-05 10:19
Open "Control Panel" > "Regional and Accessibility" > "Keyboard Layout".
Add "English (US)" so that both "English (GB)" and "English (US)" appear in "Active layouts". Then move "English (US)" to the top of the list to make it the default. Click "Apply", then "Close".
Log out and log back in. You should now see the keyboard layout indicator in the system tray with "US" selected as the active layout. Is that what you see?
#5 2026-08-05 10:21
green-moomin
Yes that works, but the problem is the layout keeps reverting every ~12hours and every time I reboot.
#6 2026-08-05 10:26
So try to reboot and check the layout. Does it revert again ?
#7 2026-08-05 10:36
green-moomin
yes it reverts to GB again
#8 2026-08-05 10:40
Do you see the GB keyboard indicator in the systray immediately after login, without touching any key ? What is the sorting in control panel module, did it change too ?
#9 2026-08-05 11:47
green-moomin
The keyboard indicator is not in the systray. The control panel module settings have not changed.
#10 2026-08-05 12:41
That's weird. It should show keyboard indicator, and when you click on the indicator you should be able to manually switch the layout.
What Q4OS version do you use, and what .iso did you download ?
#11 2026-08-09 22:53
green-moomin
I updated the system and rebooted several times - my system now looks like your screenshot, except the keyboard keeps reverting to GB.  I used the iso from the official Q4OS site.
System:
  Host: mycomputer Kernel: 6.12.100+deb13-amd64 arch: x86_64 bits: 64
#12 2026-08-10 08:22
Well, first reboot and log in.
- Do you see the "GB" keyboard layout indicator in the system tray?
Run `tdecmshell keyboard_layout` in a terminal. The keyboard layout settings window should open.
- Which language is in the first position, and which is in the second? A screenshot would be helpful.
If "GB" is in the first position, move "US" to the first position, then click Apply > OK
Don't reboot, open `tdecmshell keyboard_layout` again, and confirm whether the setting persists.
Then reboot, log in, repeat the same checks in complete as above, and post your findings.
Please follow the steps above as exact as possible. We will assess the results and suggest what to do next.
#13 2026-08-11 13:57
green-moomin
My keyboard layout settings look like your screenshot. The "us" option is above the "gb." When I re-open `tdecmshell keyboard_layout`, the setting persists. But the taskbar icon in the system tray is still "gb" and my US keyboard behaves like it is in GB layout.
When I reboot, log in, and repeat the same checks, the keyboard is still in GB layout. It only switches to US layout when I click the system tray icon (and then goes back to GB layout when I reboot again).
#14 2026-08-11 17:43
Please run in terminal and post the output:
$ cat /etc/X11/xorg.conf.d/00-keyboard.conf
#15 2026-08-11 19:59
green-moomin
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "gb"
        Option "XkbVariant" ""
EndSection
#16 2026-08-11 20:31
Well, now try to disable this file:
$ cd /etc/X11/xorg.conf.d/
$ sudo mv 00-keyboard.conf .00-keyboard.conf.disabled
Reboot and post back
