Hello all,
I have two issues in kde6 (wayland)
1) The fonts seem to be blur in some cases even I change the resolution of the screen
2) The small arrows of the task bar menu disappear when I increase the font size.
Regards
Just a comment here. I find Wayland is still new compared to Xorg or even the newer X-Libre. Is it essential that you use Wayland? Also if you have an nvidia card, xorg plays better.
Latly I have great reservations about Plasma 6.x.x as nice Tiled Menus go back to the method of setting tiles by having to mess with x and y axis settings in the tiled area. Plasma 5.27 offers the best experience - why can't KDE just leave a good working desktop alone?
ASUS PRIME X470-PRO, AMD Ryzen 7 1700X 8 Core, 16 Gb RAM, Asus GT1030 2 Gb DDR-5 Q4OS 5.9 (Aquarius)
I agree with you 100%! My system works perfectly with Xorg and the Plasma 5.27 was by far the best Window Manager. The problem with the fonts is that if I switch to X11 - kde6 then the system becomes very slow!
We can confirm the OP issues however they are not Q4OS native, but Debian/Plasma upstream.
Yes, q4os is by far the faster debian based system these days, but the combination of Wayland and Kde6 has many problems..
You can still use Q4OS6/KDE6 X11 session, it's installed by default in Q4OS. You only need to switch to X11 session on the login screen.
I will try it later and I will send screenshots from the font handling in my system.
Thank you
Please see https://imgur.com/a/11QOQiA
The font rendering issue is solved now but I had to install manually the nvidia drivers and select the X11 option
The drivers were downloaded using this tool: https://github.com/devleonardoamaral/de … -installer
regards
An this is a similar screenshot with wayland: https://imgur.com/a/jMCZWTO
I think that the fonts are a bit blur for me
