#1 2026-01-03 07:13
itsoulos
Font problems in kde6
Hello all,
I have two issues in kde6 (wayland)
1) The fonts seem to be blur in some cases even I change the resolution of the screen
2) The small arrows of the task bar menu disappear when I increase the font size.
Regards
#2 2026-01-09 13:03
swarfendor437
Re: Font problems in kde6
Just a comment here. I find Wayland is still new compared to Xorg or even the newer X-Libre. Is it essential that you use Wayland? Also if you have an nvidia card, xorg plays better.
Latly I have great reservations about Plasma 6.x.x as nice Tiled Menus go back to the method of setting tiles by having to mess with x and y axis settings in the tiled area. Plasma 5.27 offers the best experience - why can't KDE just leave a good working desktop alone?
#3 2026-01-11 08:36
itsoulos
I agree with you 100%! My system works perfectly with Xorg and the Plasma 5.27 was by far the best Window Manager. The problem with the fonts is that if I switch to X11 - kde6 then the system becomes very slow!
#4 2026-01-11 11:15
We can confirm the OP issues however they are not Q4OS native, but Debian/Plasma upstream.
#5 2026-01-11 11:34
itsoulos
Yes, q4os is by far the faster debian based system these days, but the combination of Wayland and Kde6 has many problems..
#6 2026-01-11 11:38
You can still use Q4OS6/KDE6 X11 session, it's installed by default in Q4OS. You only need to switch to X11 session on the login screen.
#7 2026-01-11 12:05
itsoulos
I will try it later and I will send screenshots from the font handling in my system.
Thank you
#8 2026-01-11 21:55
itsoulos
Please see https://imgur.com/a/11QOQiA
The font rendering issue is solved now but I had to install manually the nvidia drivers and select the X11 option
The drivers were downloaded using this tool: https://github.com/devleonardoamaral/de … -installer
regards
#9 2026-01-12 07:42
itsoulos
An this is a similar screenshot with wayland: https://imgur.com/a/jMCZWTO
I think that the fonts are a bit blur for me
