#1 2026-01-06 11:05
Broken experience with multiple desktop environments
Prerequisites
- TDE
- XFCE4 (configured and customised)
How to reproduce?
- login into TDE in TDM
- log out from TDE and choose "XFCE4 Session" in TDM
- A complete new empty uncustomised desktop environment shows up..
- log out from XFCE, choose Shutdown in TDM
- start machine, log in directly without changing environment
- customised XFCE session is back
That's.. weird?
Also, when using multiple desktop environments, I need to configure chrome completely from scratch in both.. that's painful sad
#2 2026-01-06 13:17
Re: Broken experience with multiple desktop environments
How did you install XFCE desktop alongside TDE ?
#3 2026-01-06 13:33
sudo apt install xfce4-desktop xfce4-whiskermenu...
#4 2026-01-06 16:29
Well, this is possible, but not the recommended way. We provide Q4OS tools on top of Debian in order to get a better Q4OS experience, use them where it's possible.
So we recommend you to run Desktop profiler > untick "remove superfluous packages" box > select XFCE as an additional desktop > apply profile > reboot. Now you should experience "lightdm" display manager. Login and check, if you experience the issue or not.
We also recommend to get snapshot profile after setup for a future possible Q4OS installations, see https://www.q4os.org/dqa016.html#boome
#5 2026-01-06 18:41
Oh no, that would require me to configure XFCE from scratch? I did install lightdm later and made it the default using dpkg-reconfigure lightdm, logging into XFCE with lightdm, startup apps stopped autostarting.. and I don't know what else.. so I again made tdm the default dm.
The working session type in TDM is "Default Xsession", and "XFCE Session" has that some-stuff-gone-issue.
Can I still use the Desktop Profiler and manually set TDM as default?
#6 2026-01-06 18:49
You can use TDM, but it will launch some Trinity stuff what you don't want to launch. So you likely need to use Lightdm.
#7 2026-01-06 19:01
i'm using klipper-trinity with xfce anyways so yeah I don't mind. diodon and clipman both are irritating to use when you have infinite history on, as you have to scrolling infinitely, whereas in klipper it peacefully makes a submenu when there's too many items.
It's the same reason I'm using nm-tray instead of nm-applet
Also, brightness control with xfce power manager doesn't work for some reason.. i can move the slider all I want but it doesn't do anything. Currently using Xakar to control brightness just like I used to do in TDE
#8 2026-01-06 19:18
Well, we assume using TDM. If you have installed XFCE without desktop profiler it's correct too. So back to the original issue. Is it reproducible on your machine ? Does it occur always or intermittently ?
#9 2026-01-06 20:56
Well seems like install xfce4-desktop has set the "Default Xsession" to xfce, so If I log into Default Xsession then I get my normal xfce session, if I log into TDE Session, I get my normal tde session. And if I log into XFCE session, I get a new yet another xfce session
I mean if I explicitly choose xfce session instead of default Xsession then yup it's a complete new environment. It's not that big of a deal but I think default Xsession should point to tde/xfce session instead of having a complete new session in itself..
