I am running 32 bit Trinity on an old Lenovo laptop (4gb, 150gb, pentium dual). I was trying to get wifi working and found I needed to make a connection first. I ran: sudo rfkill and it shows:
ID TYPE DEVICE SOFT HARD
0 bluetooth tpacpi_bluetooth_sw blocked unblocked
1 wlan phy0 unblocked unblocked
It connects and works fine. My question is minor. Is there a way to make it reconnect automatically?
Right click on tdenetworkmanager applet, click edit connection, choose your connection, next next, check "Autoconnect to this network", save and connct
I cannot seem to find this option. Not on the older 32 big version. Your quote mentions Asus-E202SA and that seems to be a 64 bit processor?
System tray > network icon
I am with you until your final screen. It appears the 32 bit edition -does not have- the autoconnect button. Is this something left out?
@Digidoc
What Q4OS version are you using ?
$ get-q4os-version
$ uname -a
