After I installed this app, it did not appear normally: the window was very long and could not be reduced; the meanu-bar showed brackets instead of words. Please help.
What desktop environment are you using ?
maybe I will wait for the next distro.
It's important for us to know:
- What desktop environment are you using ?
in order to reproduce and investigate the issue.
You can try fix the issue, execute in terminal:
$ sudo apt --purge autoremove goldendict*
$ cd $HOME && rm -rf .local/share/goldendict .cache/goldendict .cachekde/goldendict .config/goldendict
$ sudo apt install goldendict
- Don't run Goldendict and reboot
- Login to the session, run Goldendict and post back the result.
With the latest update of Q4os, this is not a problem anymore.
Thanks for the feedback ![]()
