#1 2025-11-12 04:06
mdre808
Goldendict issues
After I installed this app, it did not appear normally: the window was very long and could not be reduced; the meanu-bar showed brackets instead of words. Please help.
#2 2025-11-12 13:19
Re: Goldendict issues
What desktop environment are you using ?
#3 2025-11-13 09:40
mdre808
maybe I will wait for the next distro.
#4 2025-11-13 10:37
It's important for us to know:
- What desktop environment are you using ?
in order to reproduce and investigate the issue.
#5 2025-11-13 10:37
You can try fix the issue, execute in terminal:
$ sudo apt --purge autoremove goldendict*
$ cd $HOME && rm -rf .local/share/goldendict .cache/goldendict .cachekde/goldendict .config/goldendict
$ sudo apt install goldendict
- Don't run Goldendict and reboot
- Login to the session, run Goldendict and post back the result.
