Been delaying my Q4OS 6 installation because there are a few AI/ML python packages i use, which are not yet ready for python 3.13 which debian Trixie uses.
I do remember trying to compile python 3.9 on my Q4OS 5 installation back in the day but it was a too long of a process and I don't really wanna go through that again.. i also don't want to multiboot various q4oses..
Is there any way to install python 3.12 or 3.11 in like /opt/python3.xx (so it doesn't break the base system) without needing to compile from source? Like is there any PPA which could maybe work out for me? If I need to compile nevertheless, how do I skip extras like python test suite n stuff..? I just need a python installation so I can code in peace, after it finishes I'd just run it in latest raspberry pi os (debian bookworm; python 3.12) on a 3b+
This is the only thing keeping me from trying Q4OS 6 which I was so impatiently waiting for, any help would be appreciated!
If you really just want to code, you don't need any python installation.
Otherwise, since you can't install missing packages from Debian 13 repos, you might try to install them using `pip3 install <package>` within a venv.
Also, note that if you compile from source, there is an option `make altinstall` (see the comments at the beginning of the Makefile built by ./configure) that might fit your needs.
well ofc i wanna test the code out too ![]()
those packages aren't ready for python 3.13 yet.. so its not even available on pip yet
ig i'd upgrade to q4os 6 anyway and just run python 3.11 or 3.12 on windows (dualboot)
Just for my information, I'm curious to know the names of those AI/ML packages usable with python 3.12 that need newer version to be usable with python 3.13.
Well mediapipe for starters, i could use dlib like i did two years ago but mediapipe tasks and solutions are just way faster
numpy 1.26.X is also for upto python 3.12 only
(Been working with 1.* since the start and heard that 2.* brings a lots of changes, tried out running the old codes with 2.* but didn't work out well so decided to stick with 1.* for now)
Thanks for your response. It was the occasion for me to learn more about source packages and binary packages (wheels).
Now I understand your problem much better: mediapipe has no source package available, only wheels, but none for python 3.13 yet.
Yup, no problem ^^
