#1 2025-07-03 18:54
akg
Best firewall
I need a firewall that can block all outgoing connections, exept from specific programs.
what is the goto solution for this, using q4os
Thanks
#2 2025-07-04 01:44
Re: Best firewall
Look here,  https://xtom.com/blog/the-7-best-linux-firewalls/
#3 2025-07-04 07:04
Re: Best firewall
A firewall is normally used to block INcoming connections. The default Out/In is Allow All/Deny All.
ufw with gufw to manage it is one of the most popular and simple linux solutions.
If you are planning on denying outbound connections be prepared for a learning curve smile
#4 2025-07-06 03:44
Re: Best firewall
I'm curious to see where this goes.
