#1 2025-02-17 19:12
oakenshieldman2025
Security and other updates
Does Q4OS receive regular Security and other updates, kernel, etc. from Debian since it is Debian based, or are they released by Q4OS?
Thank you.
#2 2025-02-17 19:51
Re: Security and other updates
Q4OS does receive Debian updates that are typically done thru regular Q4OS updates.
#3 2025-02-17 22:30
You need to install Update Manager from the Software Centre (otherwise you'll have to `sudo apt update && sudo apt dist-upgrade` manually from time to time).
#4 2025-02-17 22:54
If youre using the KDE version of Q4OS, Discover will alert you to updates available for install. Discover has improved a lot and is the default in KDE presently.  With TDE you can also use Synaptic package manager to check for updates from time to time.
#5 2025-02-17 23:26
oakenshieldman2025
Thank you!
