#1 2025-01-26 15:23
[Solved] Q4OS 4.12 with MPV v0.33.0?
Hello,
Q4OS 4.12 (as of May 2023) gets (via Synaptic) mpv v 0.33.0 - of Nov 22, 2020.
But there is a security fix release of v. 0.33 out: mpv v 0.33.1 - of April 5, 2021 - see https://github.com/mpv-player/mpv/releases
Why doesn't this fix apply; is it because oldstable Bullseye had alredy ,closed the gates'?
Could i try sudo apt update?
Thank you
#2 2025-01-26 15:54
Re: [Solved] Q4OS 4.12 with MPV v0.33.0?
Debian Bullseye mpv version is 0.32.0-3, see https://packages.debian.org/bullseye/mpv
This is a question to Debian developers.
Yes, just try that.
#3 2025-01-26 15:56
You can also try flatpak version of Mpv
#4 2025-01-26 16:26
Thank you @q4osteam, so i'll try to build an own version... https://www.q4os.org/forum/viewtopic.php?id=5163
