#1 2025-01-21 01:15
notlurking
KLCDDimmer
Hello to all. Can someone please help me set up the KLCDDimmer correctly. Love TDE. Thanks
#2 2025-01-21 02:49
Re: KLCDDimmer
You can move the mouse over the tdeowersave icon and use the mouse wheel to adjust brightness, if thats all you need.
#3 2025-01-21 09:53
Re: KLCDDimmer
klcddimmer-trinity uses xbacklight as the backend, so you need to install and configure it first. Configuring klcddimmer should be easy and intuitive then.
#4 2025-01-21 19:02
Re: KLCDDimmer
Take a look at this,   https://klcddimmer.sourceforge.net
Tdepowersave functionality with mouse or touchpoad gesture is essentially the same.
#5 2025-01-23 12:42
notlurking
Re: KLCDDimmer
Thanks to all. Love Trinity...
