#1 2024-10-23 02:32
Gualberth
Gualberth
Hello, how are you, I'm having problems trying to connect to the internet using this operating system (I'm a beginner using Linux). The main problem is that it does not detect any wifi network. I hope you can help me.
#2 2024-10-23 08:59
Re: Gualberth
Please try to follow https://www.q4os.org/forum/viewtopic.php?id=4698 and post back. In order to get a proper assistance we would need more info, see https://www.q4os.org/forum/viewtopic.php?id=3502
#3 2024-10-23 09:18
Re: Gualberth
First of all, please don't use your username as the title of your original post; change it to something like "WiFi network not detected".
Now, check the following:
  • Does your computer have a WiFi adapter?
  • Is it enabled? Open a Terminal or console, type (without the quotes) "sudo rfkill" (you'll be asked for your password), and post the output.
  • At the bottom right of the screen, next to the clock, is there a network icon? (If you don't know, hover them with your mouse cursor).
  • What does happen when you click on that network icon?
Edit: Hmmm, q4osteam has responded faster than me.
