#1 2024-10-06 19:39
leinad47
How to uninstall softmaker office
Hello! I am new to Q4OS and am still learning how to use it. I installed softmaker office 2021 as a deb. file by double clicking on the file. Now I need to uninstall it and I tried sudo apt-get --purge autoremove packagename, but i did not work. What else can I do? Thank you a lot!
#2 2024-10-06 20:50
Re: How to uninstall softmaker office
What do you mean by "did not work"? Did you see an error message? Which one?
Are you sure you used the correct "packagename"? Otherwise you could try apt list --installed packa* to get the list of installed packages whose names begin with packa
#3 2024-10-06 21:01
leinad47
Thank you for your promptitude. It did not work, i.e the package could not be found (softmaker-office-2021_1068-01_amd64).
#4 2024-10-06 21:45
The name of the package is probably shorter than that. Use the tip I gave in my previous message (e.g. with softmaker*).
#5 2024-10-07 03:04
Should be to uninstall,   sudo apt remove softmaker-freeoffice-2021
or              sudo apt remove softmaker-office-2021
#6 2024-10-07 15:25
leinad47
Thank you all for helping me. I used „sudo apt remove softmaker-freeoffice-2021” as suggested and finally I got rid of softmaker.
#7 2024-10-07 20:12
Glad that worked,  smile
