#1 2024-06-16 18:38
ivandebcn
computer freezes
Hello, I open two or three windows and the computer freezes, it does not react, I have tried to clean the system with the terminal but it remains the same. Does anyone know how to factory reset and thoroughly clean q4os? thank you
#2 2024-06-17 12:59
Re: computer freezes
If you want to have your system in the same state as it was just after you installed it (= reset), then just do a fresh install.
