#1 2024-05-22 14:44
How do i delete a file or folder on a usb drive?
When plugged in, the contents of a usb stick can be viewed and accessed eg. via konqueror, it's location is "system:/media/sdb1".
But how can one delete e file or a folder on it - the context menu entry (Move to trash) is greyed out?
I didn't find anything useful on the web so far.
Thank you
#2 2024-05-22 19:24
Re: How do i delete a file or folder on a usb drive?
Most likely you don't have write permissions. Try to remove files as root.
#3 2024-05-22 20:35
Thank you, q4os-team.
Just a little bit intricate but so it works!
