#1 2024-03-30 05:58
Peter Linu
[SOLVED] Login
Hiyall,
I'm back after a break. I installed Q4OS full 32bit on an old Netbook. It took 3+hours! Is that normal?
I am now at the login window. Left part says 'Admin Q4OS / adminq'.
The right hand side asks for my username & password which I entered but it wouldn't allow me in.
What do I enter?
Q4OS 5.4 Trinity 32bit Full on Asus EeePC 1011PX (2011), Atom N455, 2Gb DDR2 RAM, 256Gb SSD
#2 2024-03-30 08:50
Re: [SOLVED] Login
Peter Linu wrote:
Hiyall,
Please run inxi -Fxxx in a terminal and post back the result.
What do I enter?
Use (one of) the matching pair username / password you have created during the install process (you certainly was asked to type the password twice). Nothing else exists.
That said, since you see  'Admin Q4OS / adminq', I'm wondering if you really installed Q4OS or if you are just running a live version (which is indeed very slow compared to booting an installed version); in this case the default password for adminq is empty (see here).
#3 2024-03-30 08:56
Peter Linu
Re: [SOLVED] Login
How do I send an inxi if I can't arrive at desktop?
#4 2024-03-30 09:03
Peter Linu
Re: [SOLVED] Login
adminq and empty password didn't work either!
#5 2024-03-30 09:09
Re: [SOLVED] Login
Of course...
For the password, you can boot from a live media and reset the user password (provided you didn't choose to encrypt your HD). Long to describe here, but many tutorials exist on the web. In short: edit /etc/shadow on the installed drive to empty the password field for your username; the next time you'll be asked your password leave it empty.
Simpler solution: reinstall.
#6 2024-03-30 22:29
Peter Linu
Re: [SOLVED] Login
I installed it. It still took 3-4 hours! I ask again, is that normal? I think I forgot to enter my 'complete name'. If so, why did the OS allow me to go further?
#7 2024-03-31 08:05
Re: [SOLVED] Login
Optional parameter. The user is free to enter whatever he wants, or leave blank. You may consider it as a kind of comment to the user name.
