Hello,
I have a HP Elitebook 8560p with maxed out corei7 4core gen2 running at 2.2 (3.0Ghz turbo) 8gig ram with ssd and system reports
Advanced Micro Devices, Inc. [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] for graphics - (which is what system is using)
when using the live plasma environment to install while using the docking station and attached dell U2414H 17 inch display, when setting max resolution for the display 1920x1080 at 60 hz the scaling is way off, as is the refresh which flickers badly -- it still syncs but fine details flicker
when installing from 64bit trinity install cd and picking plasma as the display manager after reinstalling in the system profiler the problem is gone, everything works as normal no graphical issues.
additionally
if you do
sudo shutdown -r now -- the system reboots normally
however if you pick reboot from the application launcher the reboot hangs at 'your system is rebooting' along with the time and date.
to get the system to proceed you need to hold the power in to get it to shut down. pressing ctrl alt del does not work.
Hello.
To reboot the system, type the following command (as user, not root)
systemctl reboot
To shut down the system, type the following command (as user, not root)
systemctl poweroff
If these commands give you an error, copy them from the terminal and paste them into your message.
