#1 2023-11-10 15:56
premio53
Question about wine
I started using Q4OS some time ago but for some reason there are almost no windows programs that will run under wine.  I have run pure Debian with the same problem.  Even though Ubuntu is pretty good with wine  working, even those distros based on Ubuntu have the same problem.  For example I have several chess programs that run well under wine in Ubuntu but not under any other distros.  Is there something I have failed to activate that prevents these programs running under wine?  I also have a couple of Bible programs that run well under wine in Ubuntu but under no other distro.  I'm completely baffled by this.  I love Q4OS and want to continue using it but the wine problem needs to be addressed somehow.  I'm using Q4wine.  Thanks for any help.
#2 2023-11-10 16:12
Re: Question about wine
Wine doesn't work well with more complex Windows applications. We can only recommend you, if you like Ubuntu, to give a try Quarkos, what is Ubuntu based system with Q4OS amenities https://quark-os.sourceforge.io/
#3 2023-11-10 16:41
premio53
Thanks a lot.  I'll check it out.
