#1 2023-03-27 02:46
danielson
Q4OS 5 testing is out on Distrowatch - but no details listed.
They are quick on the gun!
DELL Optiplex 7060 - 8G RAM.
#2 2023-03-27 11:21
BonusBrain
Re: Q4OS 5 testing is out on Distrowatch - but no details listed.
Installed today onto a Dell OptiPlex 3060 and tried all my years of experience to break it doing all the things that usually do but it doesn't. Excellent effort.
https://imgur.com/A0Ycv9Z
#3 2023-03-27 11:25
danielson
That's good to hear! smile
Downloading it now....
(strange, S.F. download count seems out of order).
#4 2023-03-27 11:29
BonusBrain
A few items you might want won't download directly from the Software Center but you can just use Synaptic instead.
#5 2023-03-27 13:35
#6 2023-03-27 14:42
danielson
Always install Synaptic.
Helps for HP driver install.
#7 2023-03-28 07:19
This seems to be a UEFI only version - certainly when it comes to Virtualbox anyway.
#8 2023-03-28 09:18
Yes, this bug is now fixed, image "q4os-5.0-x64.testing-r2.iso". Download https://www.q4os.org/downloads2.html
#9 2023-03-28 09:29
Thank you.
Having tested in UEFI so far this does look like a very nice release. OK I'm no fan of Plasma but I could be converted - it seems a lot less 'fragile' than before.
#10 2023-07-03 23:23
To danielson the HP drivers are also in the software center.  Synaptic at least in my opinion should be installed by default rather than having to use the software center or Discover.  If the software center or Discover has issues some users might not have any recourse. Experienced users will know what to do but npt inexperienced ones.
To bin Plasma hasnt been fragile for quite some time and offers a level of customization you dont get with many other DE's.
