#1 2023-03-06 08:10
sagsaw
[SOLVED] Recompile Kernel
I have installed latest q4os 32 bit.
I want to recompile kernel making some changes.
Can anyone help on how to recompile it?
I can see the conf file in /boot directory. I want to make some changes there and recompile it.
#2 2023-03-06 13:13
Senas Komunistas
Re: [SOLVED] Recompile Kernel
Hello. If you want to recompile kernel, check this https://kernel-team.pages.debian.net/kernel-handbook/
#4 2023-03-06 13:30
sagsaw
yes i have seen that but wanted to know if there is anything q4os specific and also the config for q4os as ig is if i can get as i only want to change the lernel timer from 250 to 1000.
thats the only change i want to do for which i need to recompile the kernel.
#5 2023-03-06 14:14
sagsaw wrote:
... wanted to know if there is anything q4os specific ...
No, Q4OS uses the default vanilla Debian kernel.
#6 2023-03-06 14:45
sagsaw
ok thanks.
What about the config files. when i download the kernel sources and do make etc. without any changes will it produce the exactly same kernel as in distro?
#7 2023-03-06 17:41
sagsaw
I tried following the instructions in debian kernel wiki and kernel handbook .
uploading screenshots of errors i am getting ...
sudo apt-get install build-dep linux fails
attached screenshot
#8 2023-03-06 17:47
sagsaw
when i am downloading sources via apt-get its downloading linix-5.10.162 whereas uname  -r shows 5.10.0.21-686-pae
attached screenshot
#9 2023-03-07 10:40
sagsaw
ok realized apt-get should run as normal user to get the sources.
#10 2023-03-09 07:59
sagsaw
Recompiling takes a huge time on Via C7-D 1.6ghz  single core processor
In the mean time, I installed mx kernel which comes with config_hz 1000 and also installed debian kernel from backports 6.1
the 6.1 kernel is visibly faster and Debian is going to include it in their Debian 12 as standard kernel.
So I am happy using 6.1 from backports. After mxlinux also create theor own 6.1 kernel woth 1000 hz will let know the results.
as of now am happy using 6.1  kernel from debian backports.
#11 2023-03-09 10:46
You can install Debian backports kernel including matching firmware easily in Q4OS, see https://www.q4os.org/dqa011.html#system.6
#12 2023-03-09 12:16
sagsaw
Done that by adding debian  backports repository.
