#1 2022-07-09 02:27
compis
Bluetooth send a file fail
I am runninng kernel 5.10.15-amd64, I can pair with my phone but when I try to send a small text file 100KB from my Q40s to phone it fails. On the same workstation I booted to another O.S. did the same function and it worked, this eliminates the hardware as being faulty..
#2 2022-07-10 00:02
compis
Re: Bluetooth send a file fail
Strangely only a text file cannot be sent via Bluetooth but other files can be sent. There is no problem with the file as I can send it on another O.S. on the same machine to the same phone. I have enclosed the file for evaluation. Note I have another issue open called system update message in which there is a problem with updates being incorrect that may be related to this issue.
